Old 01-08-2015, 07:21 AM
Camillo Camillo is offline
Default RV and flat spins
Hi. I searched but found no specific thread on flat spins on RVs.
I am at in the middle of my aerobatic rating and was wondering if I need to be formed on recovering from flat spins.
My instructor shortly told me that if I will enter in a flat spin I will be dead and added that he will show one to me but it is not part of the training.
I was wondering if the event of entering in an unintentional flat spin could be possible in a RV.
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 01-08-2015, 07:38 AM
Raymo's Avatar
Raymo Raymo is offline
Check out this series of videos by a fellow RV'er. I believe they did flat one or more flat spins.
https://www.youtube.com/watch?v=rb_lKYuKxvU
Ray
Old 01-08-2015, 07:49 AM
mosquito's Avatar
mosquito mosquito is offline
The 'bouncing ball' AOA/stall audio alert in the video seems very intuitive. Does anyone know what box is generating that?
-jon
RV-6 | O-320 | Triple-bladed Catto
Old 01-08-2015, 07:53 AM
n468ac's Avatar
n468ac n468ac is offline
Exclamation
Thanks.
Camillo
YES you can flat spin and RV ... at least a RV6A ... DON'T DO IT! I took me little over 5000 feet to recover.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 01-08-2015, 08:03 AM
Ok. But should you want to volontary enter in a flat spin or may it be possibile to enter unintentionally?
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
Old 01-08-2015, 09:19 AM
Sid Lambert Sid Lambert is offline
In a -9? I doubt you could ever do it unintentionally. You need specific airspeed, specific power, specific rudder and specific stick inputs. In a -9 you'd never really be in those situations since you shouldn't be doing aerobatics.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 01-08-2015, 09:27 AM
DanH's Avatar
DanH DanH is offline
Perhaps one of our resident acro guys could write a few words about how a flat spin is entered, so everyone knows what to avoid.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-08-2015, 09:36 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is online now
They do take some room to recover, but it will be dependent upon W&B among other things. A 160hp wood prop equipped aircraft will likely need more time to recover than one with a 180/200 and a Hartzell BA prop, for example.
I found that in my -6A, flat spins must be encouraged with opposite aileron and adding power (much like I learned to do them in a Citabria). The -6As rotation rate is rather exhilarating if you're used to spinning something like a 150 or a cub I guess, and going flat makes it seem even more so.
Getting out of them was really just centering the stick and pulling power to idle and once that was done, the nose dropped back on it's own. It was normal spin recovery at that point. I need about 1500 feet for a recovery from a fully developed spin; if the spin was less than two turns or so, recovery altitude needed is about half.
If you have the training to do it, have been through a (non-flat) spin series, have a chute, etc. I see no reason to not give it a go. Start high - way high - and build up carefully. I started my spin tests at 10k AGL.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 01-08-2015, 09:38 AM
ChiefPilot's Avatar
Normal spin, then opposite aileron + power.
I don't do them as a normal event in the RV since it's not terribly kind to the crankshaft, prop flange, etc.
Old 01-08-2015, 09:45 AM
sandifer sandifer is offline
Then you did something wrong for the first 4,000' or so. It wasn't the airplane. But I'm glad you figured things out.
Flat spins are very misunderstood. There is no such thing as a 'flat' or non 'flat' spin - only varying degrees of flatness, ending with the nose level with the horizon. The video referenced above is only very mildly flattened due to the very low power setting. Most aerobatic airplanes will not flatten out simply by letting a normal power off spin develop. They require flattening inputs, and will only signifcantly flatten in one direction. With Lycomings and upright spins, that's with left rudder. Right rudder inverted.
The airplanes you want to avoid developed spins in are the ones that will flatten out on their own and become unrecoverable. Unfortunately, nobody knows what all these types are, since few GA aircraft are fully spin tested. Don't do spins in unapproved aircraft or those for which spin characteristics are unknown. I would suggest against spinning anything with full wing tip tanks. Google 'Tipsy Nipper flat spin' for an interesting video and story. The issue with very flat spins is that there is very little airflow moving across the rudder to oppose the yaw.
Back to RVs - You may be entering test pilot territory by deliberately applying inputs to produce as flat a spin as possible. After establishing a normal left rudder power off spin, this would involve full aft stick, full right aileron and full power. I don't know of any RV pilot who has done flat spin testing at the edge of the envelope, and has sufficient spin expertise to provide good information on them. But maybe there are some of you, who maybe just haven't spoken up here in the past on this subject. I'd be interested in the information since I no longer have an RV to play with. Nearly all aerobatic airplanes will recover from flat spins. You will not necessarily die. But in aerobatic airplanes, flat spins are a gyroscopic maneuver, done intentionally.
Unless you have had advanced spin training specific to the aircraft you are flying, your best bet for recovering any type of spin (assuming you maintain situational awareness) is PARE. If you have lost situational awareness, your best bet is to pull power off and neutralize (move to center) all three flight controls, and wait for recovery.
That being said, the most efficient ACTIVE flat spin recovery method for most aerobatic airplanes is full power, opposite rudder, stick forward to some degree, and in-spin aileron. Yes, I know we all learned that you should always pull power off for spin recovery. Don't misunderstand - I'm talking about ACTIVE recovery via refined practice. This is very different from the concept of emergency spin recovery technique, which absolutely should involve pulling power as the first step. In-spin means aileron in the direction of the roll component of the spin, not necessarily the yaw direction (inverted spins). But by all means, if you have tried PARE, or pulled power off, centered all the controls, and are not recovering any type of spin after 5+ seconds have passed, you need to try something else. The Tipsy Nipper pilot that I mention above did just that, and it saved his life. But this aircraft had unusual spin characteristics, atypical of most aerobatic aircraft.
Keep in mind that with metal props, high power flat spins apply a LOT of gyroscopic stress to the crank flange. I would NOT recommend anyone here go play with these unless you have a high level of expertise and experience with advanced aerobatic spins and are willing to play test pilot. If this describes you, then nothing I'm writing here needs reading. There just isn't an existing knowledge base with the entire spin matrix in RVs as there is for more serious acro ships (Pitts, Extra). Until that knowledge base exists, I'd tread cautiously. By 'knowledge base', I mean the full matrix of spin testing across all aerobatic RV models, across the entire acro W&B range.
I never tried serious flat spins when I had an RV, but I strongly suspect that any aerobatic RV model, properly loaded, will recover from a fully flattened spin (full power, outspin aileron) by pulling power off and neutralizing the controls. It should recover a little more quickly with normal PARE. Folks have been known to produce accidental inverted flat spins by kicking too early on hammerheads and being way too aggressive with forward stick (full forward stick). Folks have also gotten into accidental inverted flats doing shoulder rolls. There was a fatal Skybolt crash this year associated with that. Accidental upright flat spins are uncommon. I can't think of a likely scenario for encountering an upright flat spin while doing RV acro.
Be aware that many airplanes strongly react to even simple aileron inputs, forgetting full power. The Clipwing J-3 Cub I used to fly had extremely straightforward spin characteristics - just like a standard longwing Cub. Fully-developed, recovery was within 1/4 turn. But if you applied full right (outspin) aileron during the left rudder power off spin, it would flatten slightly. The rudder then felt eerily disconnected with almost no pressure. After applying opposite rudder, in-spin (left) aileron, and forward stick, it took nearly a full turn to recover. Big difference in character compared to a neutral aileron spin. It's been a long time since I've done spins in RVs and I don't remember the specifics on how aileron-affected the spins were, other than simply accelerating the rotation a bit.
Bottom line in any aerobatic airplane, if you pull power and neutralize the controls the moment the airplane breaks loose or otherwise starts doing something unexpected, you will almost immediately recover. Admit you have lost control and don't fight the airplane. Get good aerobatic/spin training.
