Hi together,
Today I prepared everything for riveting the rear upper skin on my -8.
I found that the control cables for the rudder rubbing on the lower longeron at the rear section of the fuselage. I've checked the manual but found nothing
Is it okay to install a simple edge guard on the longeron? Iam looking for a simple solution.
Second question. Is there a proposed rivet sequence? I would start with all bulkheads an go then to the longerons.
Thanks to all
