12-08-2014, 07:26 AM
Am faced with changing two cylinders on an O-320 with exchange overhauled units this coming weekend. Wondering if anybody has the appropriate "how to" section of Lycoming manual in soft copy as I suspect we'll need to select the proper pushrods for these O/H'd cylinders?
If you have the appropriate section of the Lycoming manual in soft copy and could share it I'd be grateful.
12-08-2014, 09:15 AM
Section 5 of the Owners Manual - one version here - big file...
http://www.8kcab.com/Checklists_file...n%20Manual.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
12-08-2014, 12:10 PM
Thanks, Gil - that's just what I was looking for!
01-04-2015, 11:29 PM
Finally I checked all the Cam travel in my O-320 B3B engine....
Exhaust cam travel, Cyliner 1/2/3/4 = 0.352"/0.333"/0.348"/0.359"
Intake cam travel, Cylinder 1/2/3/4 = 0.349"/0.346"/0.348"/0.351"
Only cylinder #2 exhaust cam travel is a little bit weak = 0.333", all others are right around 0.350". Good to know that the cam/tappet doesn't have abnormal wear. Thanks for the advise. It's a great learning experience.
My next task is to bring Dry tappet clearance back to spec (0.028" -- 0.080").
01-04-2015, 11:53 PM
Adjustable? Why? If you're out of spec, change the push rod for another size to bring it in spec. Pretty easy to do.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
01-05-2015, 07:02 AM
Rockers can also vary slightly, you may be able to accomplish some changes by swapping rockers between cylinders if you are doing more than one cylinder or have extras rockers.
Bill Greenley
My RV-10 is now travel, watch out world!!!!!!
01-05-2015, 01:27 PM
Recently replaced two cylinders with overhauled units on an O-320-E2G. Overhaul shop indicated that -12 pushrods were really uncommon for installation with overhauled cylinders. I knew I had removed one -12 and the other three units were -13's. Just to be safe I ordered a set of 4 -14's and 4 -15's. When we installed the overhauled cylinders we found that one valve definitely needed a -12 (thank goodness we had one on hand). Two valves required -13's. The last valve was just barely in spec (0.030 clearance) with a -13 pushrod and could well have done with a -12 rod.
All of this just to say... make sure you've tried all the options as far as different pushrod lengths.
01-05-2015, 02:04 PM
Any one has the experience with adjustable push rod? if so, where did you get it?
Interesting that #2 & #3 exhaust have such different lifts when they both operate off of the same cam lobe. What and I missing?
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
01-06-2015, 12:37 AM
Hi Mel,
That was an over all travel, included the tappet.
Since I'm going to replace all the tappet sockets, I'll re-measure it again to confirm the number.
My dial indicator setup was a little bit awkward at the time of test, I finally bought a nice tool to finish the job.
This is the tool I bought from Harbor Freight, it worked very well checking the cam travel. I didn't use their dial indicator, I have a better indicator to do the job.
Here is the link for the tool....
http://www.harborfreight.com/clampin...tor-93051.html
01-06-2015, 12:40 AM
Dry Tappet clearance
