Old 12-25-2014, 06:59 PM
csgj csgj is offline
Default Best second com/VHF receiver
Thinking about putting in a second com radio in my 6a.
Currently using my 430 Garmin only
What's your favorite reasonably priced back up panel mount?
Probably only have room for a 2 1/4 inch unit
Thanks for the info!
Craig
Craig Jace
N133JL
RV-6A
Dual EFII
Exempt But Dues Paid
Old 12-25-2014, 07:37 PM
RVDan RVDan is offline
If you are not looking for the latest product, the SL40 works well
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 12-25-2014, 08:20 PM
Walt's Avatar
Walt Walt is offline
Garmin GTR-200 panel mount or Trig TY91 2 1/4 mount.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-25-2014, 08:43 PM
moll780 moll780 is offline
icom a200.. very good, reliable and easy to use.
--2008 RV-9A
Austin TX
Old 12-25-2014, 09:24 PM
N427EF N427EF is offline
Default XCOM
Go with an xcom, I have 2 of those and no Garmin.
Less than a pound and fit into a 2 1/4" hole.
Clear as a bell on reception and transmission over 50 miles or more.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 12-25-2014, 09:30 PM
Squeak Squeak is offline
Default MICROAIR M760
Been using MICROAIR M760 REV Q TRANSCEIVER 2 1/4" for second Comm with Garmin 430W. Four years and no problems.
Old 12-25-2014, 10:03 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
My vote is also for the Icom A200. Had one for 7 years and it worked flawlessly to the point I actually used it as primary even though I had a G430W in the #1 Comm position. I changed it to an Icom A210 for the 8.33MHz channel spacing required for some international flying.
Old 12-26-2014, 01:54 AM
Barry's Avatar
Barry Barry is offline
Craig,
I have the Trig TY91 8.33 Khz radio in my 6A for nearly 2 years and it is an excellent unit.
The control head which is 2 1/4 inches easily fits in the panel and because of its short depth can fit nearly anywhere.
The main radio I fitted under the passenger seat near the antenna. However it could easily be fitted behind the baggage compartment. I have found the Trig company support to be excellent if you have questions or require the radio to be updated to the latest firmware.
Barry RV6A F-PRVM
Old 12-26-2014, 05:58 AM
blueflyer's Avatar
blueflyer blueflyer is online now
+1 for me on the Microair.
Old 12-26-2014, 08:48 AM
Smilin' Jack Smilin' Jack is offline
I have been using the MGL V6 it is quite a deal for all the features it pack. This has been my primary radio with a hand held as a backup utilizing and external antenna. Hopefully with a few modification and an addition of a gtn 650 that will be my NO 1 and the V6 will still be there as the number 2
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
