Old 12-21-2014, 04:45 PM
ShortSnorter ShortSnorter is offline
Default Build on or replace?
Good Evening All - I'll cut to the chase.
I smeared the head of a 470AD4-7 on the VS-411PP (hinge bracket). I drilled the head and popped it out with a punch but could not for the life of me get the tail/shank out. I slowly drilled with a #40 bit a little at a time and trying to push it out after drilling a bit. I finally drilled through the rivet and ended up knocking/prying the shop head off with flush dykes. When the remnants of the rivet were finally removed, the shop head side of the hole seems to have a slight "countersink" appearance. The hole itself was not enlarged or mishaped from drilling. My question is: Can I replace with the same rivet? Replace with a slightly longer rivet to fill the slightly swollen hole? Start over? Below are some pictures of the empty hole and with a new rivet inserted. Thanks for all the help!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][IMG]
Old 12-21-2014, 05:25 PM
Jesse's Avatar
Jesse Jesse is offline
Put the same size in or a half size longer.
Jesse Saint
Old 12-21-2014, 08:32 PM
rvbuilder2002's Avatar
I agree.
Same size will probably produce just a slightly thinner shop head but should still meet minimum spec.
Scott McDaniels
Hubbard, Oregon
Old 12-21-2014, 10:23 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
AD4 (1/8) rivets don't come in half sizes do they?
Use the next size up...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-21-2014, 11:22 PM
No, that is what rivet cutters are for.....
Scott McDaniels
Hubbard, Oregon
Old 12-22-2014, 04:59 AM
AltonD's Avatar
AltonD AltonD is offline
Whenever, wherever possible, use a hand squeezer. When you first start building, the hands are pretty weak. By the time you finish, you will not even think about squeezing a AD4 rivet.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 12-22-2014, 05:16 AM
Default Thanks
Thanks for input, I figured that would be the consensus but just wanted to verify.
Old 12-22-2014, 05:38 AM
Tom Martin Tom Martin is offline
For a part like this it is hard to beat the old C frame for setting a rivet. Support the spar with blocks etc to get it level and then using a hammer set the rivet. The beauty of using a hammer is that you can start with one small hit, take a look at the rivet, adjust, hit again, adjust etc, until you have the perfect shop head.
I use a hammer to back rivet many parts on the airplane, the firewall of the RV14 is a good example of where back riveting using a simple hammer works really well. Yes it is slower then using the rivet gun with a back rivet set but if you have to drill out a few missed rivets the time advantage is gone. In this case I do it free hand, using only the "set' from the C frame and not the frame itself.
Do not get me wrong, I do not use a hammer to set that many rivets on the airplane but sometimes it makes sense, and this may be one of those cases.
As always, practice on some scraps first.
There is a certain amount of pleasure in hand setting a rivet, and actually watching the shop head develop.
It is not that often that you can hit an airplane with a hammer, if feels good!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 12-23-2014, 05:57 AM
Thanks Tom, I'll give the C Frame a shot!
Old 12-23-2014, 10:11 AM
JonJay's Avatar
JonJay JonJay is offline
I drove all my main wing spar rivets with a C-frame. 1/8" rivets will set like butta'
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
