Old 12-20-2014, 08:46 PM
KHeidorn KHeidorn is offline
Default Almost Done with Fuselage Halves
Getting ready to buck some more rivets.
Does anybody know why the battery box doesn't require a doubler but the starter relay does.
Ken Heidorn,
Debur..Dimple..Rivet..Repeat...
"You're never too old to learn something stupid." - unknown
Old 12-21-2014, 12:07 AM
rvbuilder2002's Avatar
The battery box is its own doubler (load widely distributed on a large area).
If the relay had no doubler, it would be mounting to two points with a very small foot print, out in the middle of an unsupported sheet of stainless steel.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 12-21-2014, 05:47 AM
TedsNumberOneSon TedsNumberOneSon is offline
Wow... that is awesome! Thanks for posting the photos of the nearly complete fuselage section. That will serve as a motivator to get in the shop to finish the tail kit sooner and get the wings done!!! Looking good!!! Lead the fleet.
Terrell Yon
Orlando FL, KCOI Merritt Island Home airport
140173 Kits Underway
Tail kit structurally complete
Wings in progress
N87TY on hold
EAA 724 and 74 Member
Old 12-21-2014, 04:53 PM
wjb's Avatar
wjb wjb is offline
Great progress!
How are you holding your center/front sections to the bench? Looks like you have bolted into the spar pass thru ... did you custom-build a spar end piece. I'm getting close to this point, and am looking for good ideas.
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2021 donation happily made
Old 12-21-2014, 05:35 PM
Ron B. Ron B. is offline
He's a genius, he followed the plans. Van's has the block all drawn out for you to make.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-21-2014, 08:30 PM
Default Wing Support
Yes, I am a genius...
I spent way to much time on making the support. The part does not weigh that much and is pretty balanced. I used a piece of oak from a pallet and ran it through the planer to get the correct size then glued and screwed it to a 2x4.
The instructions are excellent but don't let your guard down.
Ken Heidorn,
Old 12-21-2014, 09:44 PM
Thanks for the complement about the plans Ken, and point well taken.
A lot of effort went in to the plans but some mistakes were still inevitable.
Unfortunately, because of the release schedule (trying to get fuse. kits to builders as early as possible) you first builders are doing some level of beta testing of the plans, since Mitch only had a couple weeks head start on you.
Corrections are being incorporated almost daily as you first builders find the errors, so keep the notifications coming everybody.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 12-21-2014, 10:51 PM
wjb's Avatar
wjb wjb is offline
It must be a -14 thing; no such cool stuff in my plans for the -7!
Bill Bencze
Old 01-06-2015, 06:19 PM
Default Almost Done Riveting Sides
Another week and I should be able to join the forward and aft fuselage sections.
Ken Heidorn,
Old 01-06-2015, 06:46 PM
jswareiv jswareiv is offline
Default That won't Work
I don't think they go together that way, looks like you are getting the cart before the horse.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW - Sold
