Old 12-19-2014, 08:01 PM
Maxrate Maxrate is offline
Default Aileron ding
It's a pretty small ding. Top middle part of the aileron, on the rivet line. I'm thinking West system epoxy should fix it. But it is a control surface...Any thoughts appreciated....
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
Old 12-19-2014, 08:40 PM
newtech's Avatar
newtech newtech is offline
Poly Fiber Super Fill is your friend. Very light weight semi-flexible and sands easy.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 12-19-2014, 08:57 PM
There is always a little failure on the way to success Mark. The painter will take care of it keep building
Old 12-19-2014, 09:22 PM
crabandy crabandy is offline
I have a matching pair of those on the top of my right aileron, and a divot where I dropped a wrench on the elevator, and an extra dimple punch on the lower right fuse, and......
RV 7 400 hours and counting
19 donation done
Old 12-19-2014, 11:02 PM
wjb's Avatar
wjb wjb is offline
That's nothing! Check out what happens when you forget to switch the rivet gun to the regulator and hit your rivet/skin at 125 PSI:
http://www.kitlog.com/photos/project...2014A0002W.jpg
This was a do-over for me; as the other posters said: a little bit of fill and you're good!
Bill Bencze
Old 12-20-2014, 04:45 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Super fill prep ?
What assures good adhesion ? West 105 with micro does not adhere well to aluminum. Should the aluminum be prepped before applying superfill or west/micro?
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 12-20-2014, 07:11 AM
cjhammes's Avatar
cjhammes cjhammes is offline
Here is what I've done with good success: Thoroughly rough surface with 80 grit minimum, 50 or 60 even better. Clean with acetone, fill. Sand after cure, leave the rest for painter or use your favorite pin hole fill process.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 12-20-2014, 07:38 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Super Fil instructions -
http://www.polyfiber.com/products/su...epoxyfiler.htm
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-20-2014, 01:42 PM
Chill, fill and press on. Thanks for the expert advice! PS..Checks in the mail Doug. Thanks for a great forum
Mark Malone, RV7
N442MM reserved
Old 12-22-2014, 06:19 AM
s10sakota's Avatar
s10sakota s10sakota is offline
Sorry everyone but it's so nice to see those dings!! LOL
It's nice because I thought I was the only one!
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
