Old 12-08-2014, 02:16 PM
Doug94 Doug94 is offline
Default Inop Flaps any ideas
I went up yesterday and the flaps did not extend. I cycled the circuit breaker and the flaps cycled once. Then nothing. A second attempt at cycling the circuit breaker worked again but the third and fourth attempt did not. I have an infinity relay deck and can hear the relay "click" when I try to extend the flaps.
The question I am trying to diagnose from my desk is it the relay deck or the flap motor? Any thoughts? I have heard about some flap motors that have gone hincky - I have 65 hours on the plane.
Thanks for your replies....
Old 12-08-2014, 02:29 PM
N941WR's Avatar
N941WR N941WR is offline
Common problem. Your flap motor probably needs to be cleaned out.
Use the search function to find "flap motor grease" and you should find the answer.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-08-2014, 03:12 PM
rvbuilder2002's Avatar
But since you think messing with the ckt breaker made it work a couple of time, it would be a good idea to first check for voltage at on the wire connections at the motor (while depressing the flap switch) before going to all the trouble to remove the flap motor.... it might just be a failing ckt breaker.
Scott McDaniels
Hubbard, Oregon
Old 12-09-2014, 05:49 PM
Scremm's Avatar
Scremm Scremm is offline
Another data point. I had the same symptoms. In my case it was excess grease that migrated from the internal flap gears to the flap motor. Cleaning the excess grease fixed the issue.
Claudio Scremin
N221Z RV8A Maine 600+ hrs
Old 12-09-2014, 06:16 PM
C-FAH Q's Avatar
C-FAH Q C-FAH Q is offline
Default Use this link to start
http://www.vansairforce.com/communit...ad.php?t=82373
Gary Wilcox
St.Thomas, Ontario. CYQS
RV7 Sold
www.Facebook.com/Purplehillair
www.purplehillair.com
C-FAH Q now N281CT
gwilcox3 @ gmail.com
