12-03-2014, 02:04 AM
Which bolts for silverhawk fuel servo to FAB?
Hello all I have searched here and on the net without success.
These bolts were not supplied in any of my kits.
The vans kit has no callouts.(different servos?)
Silverhawk manual says the holes are .250-20 UNC-3B Helicoil thread. Vertical induction of course with the fab
What is the an or mil spec? For the bolts.
I have read the posts re different issues with the FAB. Looking for the bolt and nut size in particular and any methods used to ensure it stays put.
Thanks in advance
Rob Rickards
Melbourne Australia
RV7 VH-RRA flying Sept 2017
Sept 2019 180 hours
=VAF=. 2019 Donor
12-03-2014, 07:24 AM
Same as RSA5?
I believe that would be standard (grade 5 or better) 1/4-20 bolt. Per Vans, make sure they have drilled heads and safety wire them.
I tried to sub an AN bolt once but they are not threaded along the entire length and can bottom out before the FAB is properly secured.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
12-03-2014, 07:50 AM
MS20074-04-03 BOLT CRS 1/4-20 THRD AN74A3
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-03-2014, 10:37 AM
Thanks!
Thanks Walt and jdeas!
Walt Thanks not just for this but also the many useful and interesting posts.
Rob Rickards
Melbourne Australia
Sept 2019 180 hours
=VAF=. 2019 Donor
12-03-2014, 12:07 PM
Check that you don't bottom out
The FAB has a thin top. If you use the AN74A3 make sure you don't bottom out the threads. Even with a washer and a doubler plate I couldn't get that bolt to fit to my satisfaction on a Bendix RSA-5
JD
RV-7 N314SY (KWHP)
IO-360-B1B
12-03-2014, 12:45 PM
I used Philister head screws. They are threaded all the way and drilled. Don't have the MS number handy. I'm not Walt and not worthy!
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
12-12-2014, 09:34 AM
Source?
I found these at Mcmaster Carr :
90124A540 Grade 5 Steel Wire-Lockable Cap Screw, 1/4"-20 Thread, 3/4" Long, Fully Threaded, Packs of 10
Per Pack
11.24
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
02-04-2015, 06:33 PM
Bolts found
For anyone else looking for these bolts in the kits I found them!
In the FAB kit would you believe. Ricght where they should be?
Bag 939 FAB 360 HW
4.000 WASHER TAB LOCK 1/ TAB LOCK WASHER
939 FAB 360 HW 1.000 MS21919WDG3 CLAMP 3/16"
939 FAB 360 HW 4.000 1/4-20X1/ BOLT, HEX HEAD
939 FAB 360 HW 6.000 K1000-3 PLATENUT
939 FAB 360 HW 6.000 AN3-4A BOLT
939 FAB 360 HW 6.000 AN960-10 WASHER (AN3)
939 FAB 360 HW 7.000 SD-42-BSLF POP RIVET
939 FAB 360 HW 0.010 AN426AD3-5 RIVETS (LB)
939 FAB 360 HW 0.030 AN470AD3-4 RIVET
939 FAB 360 HW 1.000 F 1/4 PIPE PLUG PLTD, ALLEN HD
Rob Rickards
Melbourne Australia
Sept 2019 180 hours
=VAF=. 2019 Donor
