12-02-2014, 12:44 PM
fuel tanks
Is it worth buying already completed fuel tanks for $2000, or is dealing with the sealant not that big of a deal?
12-02-2014, 01:00 PM
It's a rite of passage like any other part of the build. Just a different set of annoyances. Certainly not worth $2000 to me to avoid. Heck, you could avoid building the entire plane if you wanted, but that's not the point
Chris
Chris Johnson
12-02-2014, 01:32 PM
Tanks
Chris
What Chris said.
IMHO...Heck no but I'm pretty cheap.
I agree, it's a right of passage. Don't deprive yourself of the satisfaction. It really is no big deal. Read the tips section on fay sealing and read some builder blogs.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
12-02-2014, 01:34 PM
Be a BUILDER, not an ASSEMBLER!
If you can build an airplane, you can certainly build fuel tanks!
Please, let's get back to building airplanes instead of buying a kit and outsourcing everything.
Build your airplane, build your fuel tanks, build your instrument panel,................
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
12-02-2014, 02:36 PM
Not worth it in my opinion. Yes it was messy, yes it smells bad, but it really is not particularly difficult if you make a careful study of all the posts and builder's logs on the topic. I can say I had no surprises at all.
Ivan Luke
Hope Valley, RI
RV-7 SB
Just hung the engine!
2020 dues paid
12-02-2014, 03:51 PM
Building my tanks was messy, messy, messy. And I'd do it again. No way I'd pay someone else to do it. But that's just me.
Dale
Omaha, NE
Previous RV-7 project (sold)
12-02-2014, 04:32 PM
Tank building tid bits
There are ways to keep the mess under control. You can be sure the pro's don't make a big mess. What's the difference? Experience and not wanting to clean up a mess everytime. How do you get that knowledge without experience? Read VAF, planning, have all tools laid out clean and ready, talk to others who've done it, better yet invite a veteran builder to assist. Here's a few tidbits I recall...
You should have a helper.
Wear two layers of gloves, and peel them/replace them often. Dedicate a full box to the job if you need to.
Dispense the sealant using full size caulking tubes available at hardware or fiberglass supply stores. One or two tubes per work session.
Have a good supply of cleaned rivets ready. I soaked a bunch in MEK overnight, then poured them out onto a paper towel to dry before the work session.
Be sure all the metal surfaces have been "scratched" with scotch bright pad (only on areas that will be covered with sealant). Clean everything with MEK or equiv. and don't touch anything after without gloves on.
Build each tank in two work sessions. Session one is for ribs, session two is for the back baffle. Don't forget to put a dab of sealant from your dispenser onto each rivet tail. The pro's probably do a whole tank in one session, but they can't drink beer at work either.
Don't rush the sealing procedure, but you do need to work steadily as the sealant has a working time of two hours. Time of curing depends on temperature and probably humidity.
Place the completed tank onto the wing (leading edge up so the baffle sealant will "sag" back to make a nice bead along all the baffle corners) and add a few screws to hold it in perfect alignment with the wing so you don't get a twist set in the tank.
All off the top of my head for now. It's really not that bad and the smell is only noticeable at the beginning. The satisfaction of doing it yourself lasts much longer. For everything else there's MasterCard.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
12-02-2014, 04:58 PM
Tank
Use wax paper over the spar before placing the tank. Proseal won't stick to it.
This is kinda sick but I actually started to like the smell!
Larry Larson
Estes Park, CO
Disclaimer
12-02-2014, 05:01 PM
Also...
the satisfaction of having built the tanks yourself and finding that when you perform the leak tests and the manometer pressure increases or stays put for hours. Priceless.
Like others have said, do build them yourself. You learn by doing it rather than having others do it for you. Enjoy the build.
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
12-02-2014, 05:15 PM
Don't spare the pro-seal. It's cheap and no judge is going to inspect the inside of your tank for style points. Slather it on there...
Chris Johnson
