Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
Old 11-30-2014, 07:33 AM
330drvr 330drvr is offline
Default Fuel from manifold HELP!
We were doing a leak check at the end of the annual condition inspection. With the throttle open, fuel pump on and mixture full rich, I had fuel coming out of the #4 intake manifold (at the gasket) and eventually out of the air box. I have the Silver Hawk EX-5VA1 on an IO-360. The spark plug was dry. Clearly I will replace the intake gaskets, but what has caused this? I suspect a problem with the "flow divider" (where the injector lines come from) but is this likely? Any comments appreciated.
Bruce Brock
N174MR
RV-7A
IO-360
Dual GRT HX & Mini
Dual Adaptive AHARS
GNS 480 Navigator
Dues paid 2018
Old 11-30-2014, 07:47 AM
John Collier John Collier is offline
Default new gaskets...
Want to get in on an order of new gaskets?
http://www.vansairforce.com/communit...d.php?t=120151
I'm not a fuel system expert...but I don't see why the fuel flow divider would be an issue. I believe the dividers purpose is to divide the fuel to the nozzles and to ensure the fuel flow stops at Idle-Cutoff.
I have the same FI system as you and what you are describing is how I prime for starting with throttle/mixture and pump...so why wouldn't the fuel be dumping into the manifold?
John Collier
RV8
N774BC
Niceville, FL
Old 11-30-2014, 07:52 AM
N427EF N427EF is offline
Default Normal
Except for the leak in the intake gasket.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 11-30-2014, 08:34 AM
Toobuilder's Avatar
With the mixture rich, throttle open and boost pump on, you were dumping copious amounts of fuel into the intake port. The fact that a bunch of fuel ended up puddling in the airbox is not a surprise, but leaking out of the intake gasket indicates a problem with the gasket seal, not the fuel system.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-30-2014, 10:36 AM
Thanks for the comments. It was just SO much fuel (like a major fire hazard) that caught me off guard. If I can fix with 4 new manifold gaskets, that sounds great! (And inexpensive)
Bruce Brock
N174MR
RV-7A
IO-360
Dual GRT HX & Mini
Dual Adaptive AHARS
GNS 480 Navigator
Dues paid 2018
Old 11-30-2014, 10:42 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Correct...
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-30-2014, 10:47 AM
BillL BillL is offline
You should really study the "how it works" documentation on your fuel system. If this surprised you, imagine your surprise when you flood it and have a starting backfire. You do have a sniffle valve, right?
These injectors do not pulse (like most automotive EFI). They are continuous flow and have pressure/flow when under pressure (boost pump on) even if the engine is not running. This is the idle condition. A trickle can add up pretty quickly.
Knowledge leads to improved safety!
Bill
RV-7
Lord Kelvin:
Old 11-30-2014, 12:14 PM
Rupester Rupester is offline
When I was trying to start my engine for the first time, I had no idea how much throttle and mixture to give it. After a lot of unsuccessful cranking and horsing around with throttle/mixture, I pushed the plane back in to check other vital signs. Once in the hangar, I found 1" of raw fuel in the intake snout ... the liquid line was visible thru the fiberglass. Only then did I learn how much fuel a Silverhawk will dump when set full rich. That's why they flood so easy.... especially when hot.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 11-30-2014, 02:29 PM
rzbill's Avatar
rzbill rzbill is offline
During my fuel systems tests before Phase 1, I learned (by direct measurement) that the RSA-5 servo will flow 5 to 6 gallons per hour at the conditions noted by the OP.
Bill Pendergrass
ME/AE '82
