Old 11-29-2014, 02:21 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Originally Posted by jrs14855 View Post
Regarding mag grounding, I have not seen mention that if you have one impulse and one non impulse mag, the non impulse MUST be off for start. This happens automatically with properly wired key switch. With toggles if you forget this you may very well trash your starter.
I used DPDT switches. Power cannot be applied to the starter unless 1) The Master is ON, 2) The left mag is ON, 3) The right mag is OFF 4) The button is pushed on the stick. Additionally, with the left mag in the middle position and the right mag off, both are still grounded but you can engage the starter (for the rare occasions you may wish to do this).
This thread is as amusing as the old "ALL IN THE FAMILY" episode where Meathead and Archie are arguing about the proper procedure for putting on socks and shoes. One advocated a sock and a shoe, a sock and a shoe, and the other advocated sock, sock, shoe, shoe... all based on various scenarios with a house fire thrown in and how prepared you would be under various circumstances.
The bottom line is there are several ways to accomplish the appropriate level of functionality and safety. Do what you like, just don't do anything stupid.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 11-29-2014, 02:26 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
General opinion from other sources agrees with what I have always believed: rotating beacon, if installed, on for engine start. Strobe lights on when cleared for takeoff, off when clearing runway after landing.
If you operate stobe lights, especially at night, for start and taxi, be prepared for a LOT of flak from those who know better.
Mag wire shielding has been discussed many times on this forum. Only the mag end of shielding should be grounded, the switch end should be open.
It was already covered here...
http://www.vansairforce.com/communit...3&postcount=15
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-29-2014, 05:37 PM
cajunwings cajunwings is online now
Default Toggle Switches & Strobe Lights
As others state there are lots of ways to switch the mags on or off. I'm going with individual toggles for the impulse mag and EI and a guarded toggle to enable/disable a panel mounted push button starter switch. If I feel the need for more protection I might add a hidden switch in the power feed to starter solenoid.
I respectfully have to disagree with turning the strobes on for startup or any other time before taking the runway. The aircraft checklists that call for anti-collision lights on before start are likely referring to the red rotating/flashing beacon when aircraft still had those, not the strobe lights.
Don Broussard
RV 9 Rebuild in Progress
Old 11-29-2014, 07:27 PM
dmaib's Avatar
dmaib dmaib is offline
I think this is what the AIM recommends, as well, but I am too tired to look it up at this particular moment. If I am wrong about that, I am sure I will be notified.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 11-29-2014, 08:24 PM
RV7A Flyer's Avatar
Originally Posted by az_gila View Post
I think a modern kid would just as likely turn a key switch as press a button...
Not really possible since the key is in MY pocket, not in the switch, when I'm not in the cockpit (and yes, it's on my shutdown checklist..."Keyswitch OFF and Key OUT").
Just to throw another combination into the mix...I have toggle switches for L Mag, R Mag, and Battery Master, a keyswitch interlock which must be ON in order for the pushbutton START switch to operate.
Old 11-29-2014, 08:46 PM
Jerry Kinman Jerry Kinman is offline
Default Last Checklist
before crossing the runway hold line I use an old familiar 3-letter abbreviation:
STP
Strobes, Transponder, Pump
Been working for me for more years than I'd care to admit.
RV-8 N88GK Sold
RV-9A Slider, N188GK Project, now flying, O-320-B1A, Catto 3 Blade NLE, G3X Touch System
Restored Taylorcraft BC12-65
Exempt but proud contributor
Jerry Kinman, VAF 170
Keller, TX (T67)
Old 11-29-2014, 09:14 PM
RV7A Flyer's Avatar
Re: strobes vs beacons (the red, "rotating" kind)...
Both are "anti-collision" lights. You need at least one kind, and if you only have one, it needs to be on when during all operations unless it would affect safety. If you have both, one of the two should be on.
I think many of us have *only* strobes, no red flashing/rotating beacon, so turn them on prior to engine start.
Good point about night ops, though...might be safer to use the nav lights and taxi/landing lights only while on the ramp. Something to think about...
Old 11-29-2014, 09:37 PM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
Since this thread has drifted to starting procedures and safety, I'll add my gripe: pilots that yell "Clear!" then turn the prop a fraction of a second later. Geez, wait a few seconds for people to notice.
As for lights on before starting, that helps at night but during the day not so much. Be careful, pilots and pedestrians.
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 11-29-2014, 10:01 PM
FAR 91.209(b) is the reference.
Old 11-29-2014, 10:57 PM
Yen Yen is offline
I have wired up my plane as Don above describes it. I have a keyed master switch, down between my knees, close to the battery, plus another switch on the panel, clearly labelled. Nobody can energise anything if I remove the key from the master switch. Starting with the right mag on cannot be done, but as soon as the engine fires I flick the right mag on, that stops the starter and gives me a running engine. The downside of this is that if I need to use the starter in flight, I must turn the right mag off. If there is a failure of the left mag and the engine stops in flight, starting with the right mag on will not happen. In that case my only chance of a restart is to operate the starter and flick right mag on. When doing the wiring design I agonised over this and eventually came to the conclusion that the probability of losing the engine was too low to worry about.
