Old 11-25-2014, 02:30 PM
hlangebro's Avatar
hlangebro hlangebro is offline
Default Turbulators on gear leg fairings...
I've been pondering about the idea of adding turbulator zig zag tape on the gear leg fairings. These are essentially thick airfoils, flying at a lower Re number. A few years ago, some guy tried out turbulators on a Cessna with great result. The reason being was that 50% of the flow over the leg fairing separated. He was able to reattach it, partially, and thus reduce drag.
I am thinking about doing some flow viz with oil, to see what the flow pattern is. If it is separating, then a turbulator strip could be helpful, both nose and main fairings.
Has anyone tried this on their RV's?
H?kan Langebro
San Diego, CA
RV-7A, slider
Lycoming O-320 D1A, 160hp C/S
First flight 6-11-13
Re-engineering a Lancair 320..!
http://www.youtube.com/watch?v=AJuQ68tccTQ
http://www.mykitlog.com/hlangebro/
Old 11-25-2014, 05:00 PM
SHIPCHIEF SHIPCHIEF is offline
Here is a link from the past:
http://www.vansairforce.com/communit...ad.php?t=19474
and I just found this:
http://www.mh-aerotools.de/airfoils/turbulat.htm
Here is a place to buy a roll:
http://wingsandwheels.com/tapes-seal...ator-tape.html
Or borrow your mom's pinking shears and make some. The gear legs aren't very long.
I love experimental aircraft...
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 11-25-2014, 05:48 PM
bpattonsoa bpattonsoa is offline
If you want to do a quick test, turbulate one side of one leg. Be ready with the rudder!
Might be a better idea to do half the leg. Be careful.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
Old 11-25-2014, 05:54 PM
hlangebro's Avatar
Thanks, yeah I have seen all of that before too. Nothing really specific to the gear fairings. I think I will tuft one side and somehow install my GoPro under the wing and film it, look for natural transitions or separation. Less messy than oil Flow vis...
H?kan Langebro
San Diego, CA
RV-7A, slider
