11-22-2014, 06:39 PM
no GPS position source ( Skyview ) issue
Has anyone encountered this issue on initial startup ??
checked port settings,are per the installation manual.
thx
HT
11-23-2014, 10:05 AM
What gps are you using to connect to the Skyview?
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
11-23-2014, 11:22 AM
when you did the network configuration, did it find a gps source? If not i would suspect a wiring problem between the GPS and the skyview.
bob burns
RV-4 N82B
11-24-2014, 06:22 AM
That can happen if you aren't out in the open where the GPS signal can reach the receiving antenna.
Ken
?Aviation is not so much a profession as it is a disease.? Anonymous
Building an RV-7
Empennage complete, fuselage 75%, wings 75%.
11-24-2014, 09:52 AM
ok I will pull the plane out from hanger and try it again  , I was thinking the error should have been related with "no data " instead of missing the "source" , anyways its SV-GPS-250 GPS . since I didn't install the Avionics so didn't know much about it.
will check the ntwork configuration , thanks Bob.
thanks
11-25-2014, 09:41 AM
No need to check network as SV GPS is on serial port 5, check that port status...
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
11-25-2014, 12:56 PM
thats what Dynon tech told me to check, will go back in the cold hanger again  thanks Deene
11-25-2014, 04:51 PM
That means you have ZERO data from the GPS puck.
If you had data, but no GPS lock, you'd have a flashing "?" on the screen.
The GPS puck is one of our most reliable products, so wiring is first on the list. Assuming you didn't mess with the default settings on the screen, there's nothing to change from when it ships.
11-25-2014, 05:30 PM
I didn't mess with the default settng's and checked the port 5 settings and it was all there, there was no increase in counters only erros log does increase. Since your GPS puck is under warrenty RMA has been placed. I will check the wiring with pins before putting the new unit. thanks
P.S- its a better idea to have 2 GPS pucks for backup or atleast for 2nd skyview when I will plan to install ?? It will be a surprise if I find out its the unit was toasted even before coming up live for the first time.
thanks
11-25-2014, 06:51 PM
I had my GPS puck mis-wired, so be sure to check that! Once I got the wires going to the right pins it has worked flawlessly.
