11-22-2014, 10:23 AM
PTT wires
I know that several years ago there was an "easy" way to fish the PTT wires through the control column but can't locate it. Help??
Wayne 120241
11-22-2014, 12:58 PM
Wayne 120241
Use a vacuum cleaner....cotton ball/fine string, suck it through, pull in stronger pull string; finally, pull wires through.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
11-22-2014, 01:47 PM
No need for cotton balls etc. Just use some string and suck it through.
rgmwa
RV-12LR 912ULS
120346
11-22-2014, 03:12 PM
I used my air compressor and blew the string through. No cotton ball necessary ...
Tom
Port Orange, Fl
EAA #51411
11-22-2014, 04:27 PM
I would suggest 20lb. test out of the tackle box. It will stand a good pull around the sharp bend.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
11-22-2014, 07:24 PM
Thanks everyone.
Wayne 120241/143WM
11-22-2014, 08:20 PM
I fed a stiff wire through then attached the real wire and pulled it through.
11-24-2014, 09:49 AM
You might find it hard to do with a string that snags as some of the tubes are rather rough on the inside. Experiment with a few different types if you run into that problem. Fishing line sounds like it might be the best option.
11-24-2014, 01:42 PM
If your tube is that rough on the inside, you might want to find some way to smooth it out. If it's that rough, it can just as easily rub the insulation off the wires causing the PTT to intermittently "key".
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
