Old 11-18-2014, 01:16 PM
Jgrindol Jgrindol is offline
Default Damaged skin
I purchased a tail mostly done but am finishing trim tab, leading edges, etc. I noticed this small ding on the leading edge of the left elevator. It is to be rolled and riveted. what is the proper procedure to repair and prevent future cracks?
Jonathan Grindol
RV-8 Empennage
South Louisiana
Dues Paid 2014-2015
Old 11-18-2014, 03:29 PM
JonJay's Avatar
JonJay JonJay is offline
Appears to be minor from the photo's. That location is not prone to cracking nor is the damage near a hole. I would knock this down, gently, with a mushroom set and a back rivet plate or bucking bar, file the edge gently and deburr.
If that edge has already been broken, which it appears it might have been, you may not be able to use the above technique. You could however use your edge tool again and roll over it, gently, until it is back into reasonable shape. You could also try a hand seamer, but be warned, they are not as easy to use as they seem (seam)ha!
Always approach sheet metal repairs with a gentle touch. Work them out a step at a time.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-18-2014, 05:10 PM
Thanks JonJay,
That was my plan, but the metal is cracked as well. Would this be one of those places I should drill the end of the crack or just Debur as you suggested. Just don't want a small issue to be a bigger problem later.
Jonathan Grindol
RV-8 Empennage
South Louisiana
Dues Paid 2014-2015
Old 11-19-2014, 01:42 PM
JoeM's Avatar
JoeM JoeM is offline
If that is the edge that folds under the other skin would it be ok just to trim the damaged area back past the crack and debur? I'm not a builder yet but if the skin is covered by the other skin I would think there would be no problem.
Joe Mikus
MSgt USAF Ret Avionics Tech
Perryville, MD
Student Sport Pilot
Future RV-12 Builder?
Old 11-20-2014, 08:41 AM
Joe,
I had the same idea, but unfortunately it is on the wrong side (the top side) so hiding it wasn't an option. Rolling it over worked well, but am still looking for some insight in whether to drill the end of the crack or not. Hanging elevators today!
Jonathan Grindol
RV-8 Empennage
South Louisiana
Dues Paid 2014-2015
Old 11-20-2014, 09:34 AM
brad walton brad walton is offline
It needs to be either trimmed back or stop drilled, one or the other. I would be inclined to trim it back. Whether top or overlapped, you won't see it once it is painted and installed. That overlap is not visible once attached to the rudder, at least on mine.
Old 11-20-2014, 11:25 AM
JonJay's Avatar
Originally Posted by Jgrindol View Post
Joe,
Sorry, didn't notice the crack. As mentioned, drill it or trim it once you get it flattened out.
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-20-2014, 01:34 PM
Wilco. Thanks all!
Jonathan Grindol
RV-8 Empennage
South Louisiana
Dues Paid 2014-2015
