11-17-2014, 07:05 PM
Marking flap position
For those that have marked their flaps for position can you share your marking method. I am a big supporter of the KISS principal so I am going the no positioning system route.
Pete
Pete (AKA Yoda)
Exempt but VAF 2017 Dues Paid anyway
11-17-2014, 07:08 PM
Permanent marker lines drawn on flap at selected intervals on LH side. Quick look out to the left and count how many lines you can see (1, 2, or all 3). It has worked great for 6 years.
Philip
RV-6A - 14+ years, 950+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
11-17-2014, 07:17 PM
Pete-
I'm like you. Less is better. Full flaps is 12 seconds down, half flaps is 6 seconds down. I only use no flaps, half flaps, or full flaps. If for some reason I forget to count, I can now visually tell when they are at any of those three positions.
If you do want a visual indication, just use a sharpie where the outboard leading edge of the flap meets the wing top skin per Philip's suggestion above.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
11-17-2014, 08:49 PM
Like you, I kept mine Van's simple.
No marks of any kind because I found out for landing there are two settings, up and down.
Abeam the numbers I drop in all the flaps and trim it and keep that speed until the flair. Very simple and an easy way to make consistent approaches.
For soft field operations I lower the aileron and drop the flap to match it.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-17-2014, 08:59 PM
I printed an adhesive label with 15, 30 and 40 on it in the right spots for them to line up with the top skin. Stuck it on the left flap and covered it with the flap tape.
Bill Pendergrass
ME/AE '82
11-18-2014, 06:20 AM
I have a single sharpie mark at 20 deg.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
I use the timing method and also I have colored stripes painted on the flaps for verifying the position. Simple and works great.
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
11-18-2014, 07:08 AM
I used black pin-stripe tape on the left flap. I have 3 marks at 10, 20, 30 degrees (I think, don't even remember any more). Mostly I count to 3 for each 'notch' of flaps, and just look at the marks for reference.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
11-18-2014, 10:35 AM
Me too, I think - I used full down aileron to set the mark. I had used an inclinometer to find different flap positions, then reverted to the KISS method.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
11-18-2014, 01:23 PM
Down aileron is 15-17 deg. but that's pretty close!
