Old 11-11-2014, 07:59 AM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
Default Pre-heat help please
I own an RV-7 with a carbed O-360 and standard snorkeled cowl. I am trying to buy some supplies at Home Depot to route my heater into my cowl. I was wondering if anyone knew how big of a duct tube would be appropriate for either the exhaust exit on the cowl, or either of the inlets next to the prop. Also, is there any reason I would choose one location over the other? It seems like the exhaust exit would be easier and I wouldn't have to worry about scratching my cowl paint. It is a forced air propane heater I am using.
Thanks. Andy
Old 11-11-2014, 08:36 AM
Johnnybgoode Johnnybgoode is offline
Default Don't know exactly but...
Hot air rises so exhaust portal is what I use. Also mine is a 1100W (or maybe 1500W) electric space heater to which I've attached a piece of 4-inch flex metal dryer ducting. Don't know how easily that can be done with your propane unit but probably not too difficult.
Patrick
P.B.
Privileged to explore the world in the venerable Lockheed C-130 and the regions around NC in a work-in-progress RV-4, kit #2614, while paying the bills aboard an Airbus A-330.
Old 11-11-2014, 09:47 AM
AndyRV7's Avatar
Thanks. The heater is round so a step-down ring should do the trick. I just don't know what size hose I need yet. Sounds like 4" works for you, so maybe that is the ticket. Thanks.
