Old 04-07-2012, 09:50 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Default headset adapter harness
Recv'd the adapter harness from VANS today, they are labeled RZxxx ( i think). The Old harness has co-pilot and pilot labels. anyone know which goes to which?
I have two sets of blu/wht wht and org/wht on the adapater harness along with :
The two green/white wires from co-pilot and pilot wire sets are tied together and pinned on #37 of the options.
There is also a black/white wire which i believe ties the two grounds together into 1 pin on the "options" harness. no mention of where that is pinned that either.
looked on the diagram but it looks to be for new skyview harness only, not the adapter for headsets (for those of us that have upgraded from D-180 harnesses to skyview)
questions is, has anyone else made this change yet.
no instructions on with the harness !!!
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 630 Hrs on the Hobbs
Old 04-08-2012, 01:28 AM
Seaflyer16 Seaflyer16 is offline
Default WH-00026 headset adapter
Mine was in a package called fix1 if that is what you are talking about. The RZ194 is the pilot side. The WHT/BLK wire goes to pin 12 on the WH-00026 "Autopilot" connector. Thats the way I interpreted page 42D-20 anyway.
Old 04-08-2012, 02:27 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
Just to confirm RZ-194 is the pilot side. I tested it yesterday with the intercom. I didn't use any adapter harness. The cables are just long enough to attach them to the WH-00026 harness. I used page 42D-20 and some parts of old wiring with female d-sub pins.
PH-BZT
MyKitlog
Old 04-09-2012, 10:54 AM
Catbird Catbird is offline
Kyle,
I wired up the headset adapter harness about a week ago and found it to be rather straightforward. You have to follow the wiring schematic entitled, "Figure 2: Connecting the Headset Harness" on Page 42-20, Rev 1, dated 03/01/12 This is a very recent revision to add Figure 2 to the drawing and should answer all of your questions.
Keep in mind that RZ194 is the 4-conductor wire coming from the Pilot Headset jacks and RZ195 is the 4-conductor wire coming from the Co-Pilot Headset jacks.
Jerry
Old 04-10-2012, 09:46 AM
KALEWIS's Avatar
Thanks for all the info. Dl'd the revision page and wired it up. First test showed that I could hear the local AWOS on both sides but had lots of static. Could only volume up or down by pulling the squelch knob on the sl-40. Static remained thru all levels. I'm thinking the washers in the headset jack positions could be wrong.....
RV-12 #328
Old 04-26-2012, 06:08 PM
MacPara's Avatar
MacPara MacPara is offline
Hm, I am right on 42D-20 step 5 and I can't make sense out of it. I do have the revised page that shows figure 2. However, my harness lacks the wires that I am supposed to crimp to the Pilot and Co-Pilot Headset harnesses. The conversion harness claims to be WH-00026 but the actual harness as well as the testing diagram shows nothing attached to the pins that I am supposed to crimp the headset harnesses to. Am I supposed to add the wires and pins (the manual does not suggest that) or did I receive the wrong harness?
RV-12: #120374, ELSA, N128TL flying since Nov 28, 2013 (Phase 1 completed 1/26/14)
SkyView, Light Package, ADSB
http://torstensrv-12.blogspot.com/
APRS Track
Old 04-26-2012, 06:17 PM
MacPara's Avatar
Found it! So, for others that might have become as spoiled by Van's kit quality as I did:
Look through the whole set of harnesses in the kit. There's a bag labeled WH-00026 REV 1 KIT (or in short WH-00026 FIX-1) that contains the wires and pins. Just insert them in your WH-00026 harness.
I haven't found the reference in the manual yet that says anything about it ...
APRS Track
Old 04-26-2012, 06:24 PM
skydiverlv skydiverlv is online now
Torsten, check for 42D-20 revision 1. If you do not have it then download is available at Vans
Larry Vandegrift
ULPower 260is
Old 11-04-2014, 01:59 AM
VHRV12 VHRV12 is offline
Thanks Torsten.... "Ya Bloods Worth Bottling".... you've saved me hours of brainstrain.
Marcus Bootle.
RV120215. Empenage complete, Wing kit complete. Fuse complete. Finish kit Complete. Engine Kit 80%. 2018 Paid.
http://www.mykitlog.com/users/catego...819&category=0
Old 11-04-2014, 02:49 PM
MacPara's Avatar
You're welcome, Marcus! Always good to hear that my writings helped someone!
APRS Track
