  #11
Old 05-18-2014, 11:48 AM
flightlogic's Avatar
Jim, that is good news. A process of trouble shooting... following the links and finding a solution. And, it is really fun when it turns out to be simple.
So many times that day you set aside.... isn't even enough.
Old 11-02-2014, 03:22 PM
Paris12Man's Avatar
Paris12Man Paris12Man is offline
Default Regulator problems......maybe?
If my battery is fully charged and I only have the D180 turned on (everything else is off) and at 4000 rpm my voltage is 12.2 and amps is -2, does this point to a bad regulator? I've checked the connections and they are good at the regulator. I disconnected plug at regulator and checked the connector pins for signs of shorting and none found.
Could this be an alternator/generator issue??
Your replays are appreciated.
Steve Garrett - 903-272-5639, scg3037@icloud.com
N905RV - 520 hrs to date
Home field XS30
Old 11-02-2014, 04:07 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Check the voltage off the battery terminals or off you power port and report back.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 11-02-2014, 04:28 PM
Mich48041 Mich48041 is online now
Steve, the regulator could be bad. But test the aircraft wiring before replacing the regulator. Do the tests described HERE. Then use a low wattage 12 volt lamp and connect one lamp wire to the regulator case (not to aircraft ground nor to battery negative). And connect the other lamp wire to regulator terminals B and R and C, (one terminal at a time). The lamp should illuminate brightly. Also measure the voltage across the lamp while it is on. The voltage should equal battery voltage. Again, use the regulator case as a voltage reference, not aircraft ground. If no problem is found with aircraft wiring, then replace the regulator. Loading a circuit with a lamp will make problems show up that might not show up with just a voltmeter alone.
Other possible causes of low voltage could be an open alternator circuit, or a blown main fuse, or a half-bad master switch. If you replace the regulator, use heat-conductive grease between the case and the airframe.
Joe Gores
Old 11-02-2014, 04:37 PM
Paris12Man's Avatar
Default Battery voltage
Reporting back....... Voltage off battery is 13.14.
Home field XS30
Old 11-02-2014, 04:49 PM
Paris12Man's Avatar
Default Tomorrow's work
Thanks Joe. I'll work on your suggestions tomorrow and post what I find.
Home field XS30
The battery is fully charged. Was it charged while flying or later with a battery charger?
Joe Gores
Old 11-02-2014, 05:03 PM
Paris12Man's Avatar
It was charged after my last flight with battery charger. The reading I had today was with a fully charged battery and a ground run-up to 4000 RPM. Voltage showed 12.2 and amps showed -2 amps at 4000 RPM.
Home field XS30
Old 11-03-2014, 02:27 PM
Paris12Man's Avatar
Default Bad regulator
I followed the tests that Joe Gores recommended earlier in this thread on the aircraft's wiring today and everything checked out OK. Everything points to regulator problem.
Thanks Joe for your help.
Home field XS30
Old 11-03-2014, 04:08 PM
Heat is the enemy of electronics. The heat from the regulator needs to be dissipated both by cooling air and by conduction to the airframe. Use heat conductive grease to help conduct the heat away.
Joe Gores
RV-12 Flying
