Old 10-29-2014, 01:30 PM
Larryskydives Larryskydives is offline
Default RV-4 Spar Information Needed
Looking at buying a RV4 Have not been able to get any good information on spars. Are the spars all aluminum, or were some early on laminated wood? Looking for experiences with te woods spars versus aluminum?
Old 10-29-2014, 01:32 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Larry, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-29-2014, 02:04 PM
rvator51's Avatar
rvator51 rvator51 is offline
I have never heard of a wood spar for a RV-4. I doubt there ever was.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 10-29-2014, 04:15 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Thumbs up All metal airplane
there is no wood structure in any RV's and there never has been.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 10-29-2014, 05:03 PM
Thanks for the info. I didn't think there was but I am looking at a RV4 and the current owner said it has a wood spar. Going to look into it further. Let you know what he says. Thanks
Old 10-29-2014, 05:05 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Run as fast as you can AWAY!!!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I've seen a wooden instrument panel insert in one
Neal Howard
Airplaneless once again...
Old 10-29-2014, 05:09 PM
Neal@F14's Avatar
...I am looking at a RV4 and the current owner said it has a wood spar.
If somebody did build one with wood spars inside the wings, then it is no longer an RV-4 but something quite different, and with very unknown +/- G strength.
Neal Howard
Old 10-29-2014, 05:15 PM
Mike S's Avatar
Senior Curmudgeon
Only wood spar connection I know of---------and I am stretching it a lot----------is the RV 1. It had wood wing, but that was before it became the RV 1.
Pretty sure it it is an RV 4, the wing is all metal.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 10-29-2014, 05:29 PM
southtarnation's Avatar
southtarnation southtarnation is offline
The most likely explanation is that the seller "thinks" its wood...
And it is probably just like every other rv-4 spar, Not wood.
If someone (a laymen) looked at it from the top where it meets (or would meet) in the cabin it might look like wood due to it looking similar to several thin(er) pieces of wood that have been laminated into a single "spar".
Again though, it very likely just like every other Rv-4 spar.
scratch it and see.
Jesse
'89 RV-4, N2626C - purchased flying
Converted to Fastback - Sliding Canopy - Tall Gear
Dynon Skyview w/ acc. & VP-x Sport
Catto 3-Blade (gen. 1)
Based: KPGD
