Originally Posted by rvbuilder2002
Bad Sheila
I think it is highly likely that you have a leak in your static system that was influenced by a large pressure change inside the fuselage with the canopy open.
Easy check : Do the static source instruments respond to abruptly opening/closing cockpit vents while in flight? When I have the in-cockpit alternate static source open, the altimeter and ASI show very direct response to vent changes (on the order of 10 kt or so). Opening a fresh air vent slightly pressurizes the cockpit and decreases indicated airspeed and reported altitude.
it is not entirely inconceivable that a partially open canopy would disturb the airflow at the static ports and cause the reported error.
- Roger
