08-22-2014, 09:20 PM
UAT Antenna Cable
On page 10-23 of the empennage plans, it shows the routing of the antenna cable. I installed this tonight but am concerned where the cable passes through bulkhead F-01410 and transitions to under the j-channel as shown in the detail drawing. The cable makes a sharp turn to get under the j-channel and there is a lot pressure on the somewhat sharp edge of the aft end of the j-channel. Cable is basically bending around the edge of the aluminum sheet forming the channel. I am concerned about the integrity of this cable over time where it contacts the edge of the metal. I am thinking about wrapping the cable with a short section of spiral wrap to protect it. Did anyone else have any concerns about the antenna cable in this area?
Rob
RV-14 Flying
EAA Chapter 343 (DTN)
Shreveport, LA
08-26-2014, 05:41 PM
A piece of clear vinyl tubing (1/4") works well too as an anti-chafe measure. Just slit it and slip it over the antenna cable.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
08-26-2014, 09:13 PM
Thanks for the info. I ended up using a piece of spiral wrap around the cable. I like the tubing idea also.
Rob
RV-14 Flying
Shreveport, LA
10-23-2014, 05:28 PM
Can someone clarify what this UAT antenna cable (WH-00014) is for? Will it be for the transponder? Thanks
10-23-2014, 05:40 PM
It is for the optional ADSB transceiver antenna.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
10-23-2014, 08:11 PM
Not going to be optional in just over five years.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
10-23-2014, 08:27 PM
I have used old air hose slit to protect fuel and brake lines. The best thing was getting a new very flexible air hose.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
10-23-2014, 09:32 PM
Sure it is, just stay out of the upside down cakes!
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
10-24-2014, 04:42 AM
RV-14 are not made for that.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
10-24-2014, 09:48 AM
and below 10,000 feet.
