07-31-2007, 04:16 PM
Replacing weak lift struts
The lift struts on my -6 aren't exhibiting the same enthusiasm for the job that they used to, so I ordered a couple of replacements from Vans. Being as they're just the struts and not the original kit, they came without instructions.
Can anyone that did original installation of these struts provide some direction?
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
The Book: The PapaGolf Chronicles
Built RV-12
http://www.schmetterlingaviation.com
The Book: Being written.
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
07-31-2007, 04:23 PM
Release the spring clip...
Just pull back the little spring clip on the end of the strut and they pop right off, took all of about 10 minutes to do both. (I'm assuming the 6 is the same as the 7)
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
07-31-2007, 04:24 PM
fugio ergo sum
From possibly faulty memory. Get a small screwdriver and partially pry off the metal clip at each end. I think you just have to slightly lift the clip then you can pop that end off. Pop the new ones on. Support canopy while doing the preceding.
I put the steps out of proper order just to fit the proper format for these things.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
07-31-2007, 04:44 PM
Also, when you replace them be sure to install them with the proper orientation, which is with the cylinders up and the plungers down. I see a lot of them installed backwards (which would seem to make sense) but you'll find the action on them works better if they're installed "upside-down."
Before anyone jumps on me for this, go out and try it on your own tip-up. I started with mine the wrong way until somebody pointed it out to me.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
07-31-2007, 04:46 PM
Geez, I had hoped to delete this before anyone got to it - it was embarrassingly easy to figure out.
Not to gas on about it or strut my stuff, but what a low pressure job. My self-confidence got quite a lift out of it.
Dave Gamble
Grove City, OH
Built RV-12
07-31-2007, 04:49 PM
Hmm, the ones that were already on there had the cylinder at the bottom. Given how easy it is to get them on and off, I'm going to flip them over and see how that works. Thanks!
Dave Gamble
Grove City, OH
Built RV-12
07-31-2007, 05:02 PM
These struts are designed to extend rapidly through most of their extension, then slow down for the last inch or so. Mounting them with the cylinders down prevents this from working. Don't ask me why, but it does.
Jeff Point
Milwaukee
10-22-2014, 06:13 PM
does anyone have off hand the part # or extended length for a 6A tiltup? I am wondering why the vans struts are $33 ea when I see what looks identical at $12. [ my plane is a 45 min drive away.]
RV-6A 1500+hrs since 1997
O-320 D2J, FP, slo-bld
49 states, Bahamas, Canada
2014 - PAID
10-22-2014, 08:14 PM
Years ago I had mine installed correctly. Then Bill Benedict, (We all loved you) said they need to be turned upside down. I changed them and then they were correct. :-))))
