Originally Posted by Bubblehead
"7 to 10 gph range" Is that from full rich to lean or is it varying that much in flight after leaning? If that is the change from full rich to lean then no problem.
The 7 to 10 gph was the fluctuation I was experiencing in cruise after leaning.
It turns out I was wrong about the fuel flow being accurate. I've gone on a number of long flights and made use of the 'fill the tanks, fly and then fill the tanks again' method to determine fuel flow.
On one flight, I burned 17.2 gallons flying from Monterey to Burbank. We were at 11500 and I was around 21" and 2400 rpm (a.k.a. not economy cruise). I'm burning between 8 and 9 gph if I keep the prop spinning. I can get down to ~7 gph if I dial it back.
I'm going to check my wiring as well as the fuel flow sender to see what's causing the high flow numbers.
The good news is the everything appears to be fine with the engine with the exception of my instrument not reading correctly.
Thank you to everyone for their input. Appreciate your comments and suggestions.
Jeff
