  #11
Old 10-14-2014, 10:51 AM
JonJay's Avatar
JonJay JonJay is offline
Very funny and well written tale of horror. I was involved with one of the very first applications in an RV8 around 1998 or so. Doesn't look like anything has changed. It was indeed horrifying.....
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-14-2014, 12:23 PM
ppilotmike's Avatar
Default Stupid question?
I'll be the guy... What mod requires this to be done.. Aftermarket cowl? I thought the FAB intake was essentially right out in front.
Mike Rettig
VAF Dues Current
Old 10-14-2014, 12:39 PM
boom3's Avatar
boom3 boom3 is offline
Both cowls are available from Vans. One has the FAB air inlet directly out the front and the other uses square air filter just inside the left cowl opening.(This is the one where you need a snorkel.) The difference is vertical vs horizontal induction.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 10-14-2014, 12:49 PM
RV9A Bill RV9A Bill is offline
Default Frankensnorkle
Mine took lots of fitting on an IO- 360 parallel valve.
Old 10-14-2014, 12:52 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
This is the stock RV-7 cowl for an IO-360M1B 180hp horizontal induction setup, and the FAB came with the firewall forward kit. The engine is a factory-new stock Lycoming YIO-360M1B, and the baffle kit is also the stock Vans kit for the same engine. With the snorkel centered on the fuel injector, the FAB extended an inch past the left intake ramp and side wall. Vans confirmed that this snorkel will be too long since it's intended for the 200hp version.
Danny, thanks. I did a lot of what you described, but I'm gonna need more practice.
Paul, that looks great! I may give you a call later.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 10-14-2014, 03:36 PM
Highly impressive ductwork-ery. It might've been easier to vacuum-bag the fiberglass around the starter!
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 10-14-2014, 08:15 PM
Danny King's Avatar
Danny King Danny King is offline
Originally Posted by rzbill View Post
Danny,
Your sig file says angle valve motor. The OPs is a parallel. They are different widths.
While I imagine one can install the snorkel on a parallel valve without cutting it, its my opinion that the filter sits to far outboard and it affects the outboard baffle position negatively where it interfaces with the cowl.
Yes, I realize that the parallel valve engine has less room to work with, but one of the engines I did was a Superior I0360 parallel valve with the new metal cold air sump. The snorkel fit the same way with a little more "centering" work at the flange. I figured at the time that the difference in the fit was because of the non Lycoming sump with placement of the throttle body close, but not exactly the same as the Lycoming.
I think Van sell two different snorkels. One for the parallel valve cylinders, and a longer one for the angle valve engines. I could be wrong, but I seem to recall that one snorkel part number was: ???? and the other snorkel was the same number with a -1 after it! (????-1)
YMMV
Danny King
Beautiful Doll 80434 TT 1675 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2020
Old 10-15-2014, 05:31 AM
YMMV
Danny,
The catalog shows one induction kit (-1) for the IO-360M1B and 1B6 engines going into the -7 or -8. The dimensions must be the same.
With the -7 I trial fit a snorkel to the cold sump with AFP FM200 controller and it would have required major changes to it and or the cowl, did not use it. With the 8, same set up except FM150 controller, the snorkel fit perfect, made one small mod to clear a bolt on the starter.
Things get complicated if the fuel controller is different than what comes with Vans engines. The FM150 is the same.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 10-15-2014, 09:46 AM
Paul K Paul K is offline
Scroll,
I created a new picasa page of all the photos I took building the custom snorkel. Made lots of mistakes and would do it differently if I did it over again but here they are:
https://picasaweb.google.com/1033987...eat=directlink
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 10-15-2014, 02:14 PM
BenNabors BenNabors is offline
Paul K: Any concerns for galvanic corrosion between the aluminum rivets and the carbon? The potential voltage is about 1.5 volts.
