Old 10-09-2014, 08:37 PM
Tharpo Tharpo is offline
Talking Missing letters?
Looked at an O-320 Lycoming today that didn't seem to have any lettering after the O-320 part.Is this an early engine or do I need to look some more? The story that goes with it sounds pretty good, but want to hear more from the experts.Thanks
Blessings
Tom H.
Old 10-09-2014, 08:58 PM
chaskuss chaskuss is offline
Blessings
Tom H.
Yes, there is an O-320 that had no suffix. It would be an older narrow deck engine.
Charlie
Old 10-10-2014, 01:51 AM
osxuser's Avatar
osxuser osxuser is offline
You are probably looking at what would later be known as an A2B (FP prop setup off a supercub). The other early O-320 that didn't have a suffix I think would become the A1A, originally on a Apache. Hope that helps.
Stephen Samuelian, CFII, A&P IA, CTO
RV4 wing in Jig @ KPOC
RV7 emp built
Old 10-10-2014, 09:36 AM
NM Doug NM Doug is offline
Not an expert, but FWIW, the engine in our 9a is an O-320 (no suffix) - it's a narrow deck. The first entry in the engine logbook is from its original installation in 1955. It is a 150hp engine rather than 160. We're currently at 600 SMOH, and it runs well with normal oil analysis results.
Doug Dunston
Adopted RV-9A N191PF
Grateful VAF supporter 2020
Old 10-10-2014, 09:39 AM
Thanks so much for the quick replies. One more quick.one if I may....if memory serves I think I read somewhere that narrow deck engines should be avoided in RV's. That so?
Tom H.
Old 10-10-2014, 10:05 AM
Weasel's Avatar
Weasel Weasel is offline
Yes, they are worth nothing. I can come by and haul it off for you if its in the way
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 10-10-2014, 12:08 PM
Thanks.....I'll pass that on to the guy trying to sell it
Old 10-14-2014, 07:48 AM
osxuser's Avatar
Narrow deck can be a little harder to find parts for, but no less reliable than the wide deck. Upgrading a 150hp to more than 150hp O-320 requires a case stud change.
I have one in my Citabria and a narrow deck O-360 for my swift, not gonna worry about it. In fact, I sold a wide deck O-320 I could have put back in the citabria...
RV7 emp built
Old 10-28-2014, 02:35 PM
rgbewley rgbewley is offline
Sorry to bust your bubble oxuser, but narrow deck engines are not difficult to find parts for in any way, shape or form. All of the manufacturers, including Superior and ECI make narrow deck parts. The only real differences in the cylinders, and they use a few different push rod tube related parts as well as half moon plates at the cylinder base.
Rhonda Barrett-Bewley
Old 10-28-2014, 02:48 PM
rhill rhill is offline
The H2AD is to be avoided, Narrow deck takes plates,special(expensive) nuts,the same nuts there using on the stroker motors.
