  #11
Old 10-09-2014, 07:33 AM
Jared----we've plumb the FT60's in just about every imaginable location, and then some. Firewalls, engines, tunnels, near the flow divider, wires out the side. I cant remember anyone having any issues. Some of the guys at Team AeroDynamix have theirs mounted very near the flow divider, in a vertical position, with the wires coming out the side, pointing aft. Even with all the aerobatics they do, I havent heard of any issues.
I would make a bracket for mounting though. Just my .01 cent worth.
Tom
Ridgeland, SC
Old 10-09-2014, 07:39 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Originally Posted by alcladrv View Post
Where in your fuel line between the firewall and carb idoes it connect?
Mine is angle mounted on the lower right side of the firewall between the electric fuel pump and the engina driven fuel pump. It fluctuates about 2 to 3 gph until the fuel level in the tanks is about 1/2 full then fluctuates 1 to 2 gph. Overall, the fuel needed to fill the tank is within .2 gallons of the fuel used. It just doesn't maintain a steady reading.
No issues so far with my install. I am within 0.3 gallons reliably. The fuel line from the Red Cube to the carb is tie wrapped to the engine mount with a standoff about 2-3" long to dampen vibrations.Here is a picture of how mine is plumbed:
http://www.aclog.com/rv-9a/images/Fi...0721001346.jpg
I think the manufacture has you install so it so that fuel will tend to puddle in the Red Cube versus drain out, i.e., lowest location: "the fuel line on the outlet port should not drop down after exiting the transducer...can trap bubbles in the transducer causing jumpy readings."
Mike Hoover
Columbia, SC
www.eaa242.org/
N194MH first flight on 08-26-12
Old 10-09-2014, 01:41 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 10-09-2014, 08:25 PM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by lr172 View Post
I spoke to the manufacturer about mounting. They advised against firewall/solid mounting. Their suggestion was to let it float between two hoses.
Larry
Originally Posted by BillL View Post
This what they told me too. It has jewel bearings for the pelton wheel.
Then what are the two 1/4" machined holes for? The company needs to make up its mind. Its either for hard mounting or its not and that FACT (if it is) need to be blatantly spelled out in the accompanying paperwork. I find the presence of those two holes completely misleading especially if you have to call the factory to get the secret handshake.
Bill Pendergrass
ME/AE '82
Old 10-09-2014, 10:04 PM
bkthomps bkthomps is offline
what's the justification of not mounting it to a hard surface?
Old 10-09-2014, 10:16 PM
RV9A Bill RV9A Bill is offline
Default Red cube
Mine is on the firewall and works perfectly.
Old 10-09-2014, 10:43 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Larry
When did they tell you this? I talked with them in 2011 when we were finishing up the RV-3, and was told that while they at one time had problems with vibration getting the bearings, they had changed the design and were fine with mounting it to the engine, to something solid, floating - wherever - vibration was no longer a consideration. We mounted ours toa bracket in front of the sump, and it has been absolutely perfect for over 400 hours now.
To the OP's question - one reason to make a bracket is to allow clearance to make connections. Think in terms of removal and replacement and initial installation of all your equipment - make it easy to work on!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-09-2014, 11:54 PM
lr172 lr172 is offline
Last Spring. I am struggling to recall the rationale provided, but it wasn't bearings. They made it clear that they wanted it to float and not be rigidly attached. They may have different techs providing different guidance or some are more strongly clinging to issues had in the past. They made it very clear that no harm would come to unit by hanging from the hoses. It made logical sense to me and I decided to mount that way. Seems that the general experience is that the units are robust enough to handle a hard mount.
Larry
Old 10-10-2014, 06:58 AM
flyingriki's Avatar
flyingriki flyingriki is offline
Ditto here.
Old 10-10-2014, 10:17 AM
Snowflake's Avatar
Wow, we've come full circle then. I can recall when I was looking to install mine that the manufacturer wasn't recommending that it be mounted in-line, and many people here on VAF were uncomfortable about having that weight hang off the aeroquip fittings.
Mine is mounted to an angle bracket that is Adel-clamped to the crossbar between the two gearleg mounts (tailwheel RV-6).
Even if it *does* need to be rigidly mounted, what are the 1/4" holes for? You could probably pick up the entire engine on two 1/4" bolts. Overkill, perhaps? Maybe it's just easier to find a 1/4" x 2" long bolt than it is a 1/8" x 2" long bolt?
Rob Prior
