  #11
Old 10-06-2014, 06:32 AM
Walt's Avatar
Walt Walt is offline
Fuel pump, prop governor?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-06-2014, 07:29 AM
osxuser's Avatar
osxuser osxuser is offline
Basically, you are dealing with a front mount governor case if you want a governor, and dual electric fuel pumps like the EFII uses. There isn't even a vac pump type drive to run a rotary pump if you wanted to.
Personally, in an RV I'd take the 5lb hit to have the versatility, but probably not in a Carbon Cub.
Stephen Samuelian, CFII, A&P IA, CTO
RV4 wing in Jig @ KPOC
RV7 emp built
Old 10-06-2014, 09:23 AM
DanH's Avatar
DanH DanH is offline
FWIW, note the left side boss in the casting for a magneto, p-mag, or similar. The camshaft idler gear had to be in there anyway, so a bit of machining, two studs, and Bob's your uncle.
The Carbon Cub has a carb, gravity feed fuel (no pump), and Lightspeeds. Current electrical system is a single B&C alternator, a main battery, and a little 2AH backup battery. My guess is that EFii injection would require an accessory case with provision for a B&C permanent magnet backup alternator, as the power demand includes two electric fuel pumps.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-06-2014, 11:34 AM
rcpaisley's Avatar
rcpaisley rcpaisley is offline
Default EFII
Negative on the need for an extra alternator with EFII.
And only one pumps ever runs at a time.
Robert
EFII www.flyefii.com
Protek Performance
Old 10-06-2014, 01:35 PM
Nickb145 Nickb145 is offline
Awesome!
How much does this thing weigh? With the Carbon Tubes, you're probably shaving at least 10lbs off.
Old 10-06-2014, 01:45 PM
N941WR's Avatar
N941WR N941WR is offline
That makes me wonder how many Bush Pilots want to fly into the Bush in an all electric airplane?
Dual P-mags is one thing but dual Light Speeds is another! You can at least power the P-mags with a 9 volt battery until the engine is spinning fast enough to self power the P-mags.
I would happily take the five pound weight penalty for a non-race plane.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-06-2014, 01:59 PM
Relentless's Avatar
Relentless Relentless is offline
Default R360 weighs in!!!!
Originally Posted by Nickb145 View Post
Awesome!
Finally finished R360 engine and ready for dyno weight is 244.4 lbs! Lightspeed coils and flywheel included. This makes me very happy as I know it will push over 200hp, run nicely on lower octane fuel, and within 1 lb of carbon cub 340 this engine will be our best seller
Carbon Cub 340cc in same configuration 243.8lbs......
For comparison, the lightest 409 I have built with traditional parallel cylinders for long ez that I raced this year at Reno was 278lbs... 208hp...
R409 in the RV8 with traditional accessory case, gears, B&C alt, Efii coils, etc. was 294lbs........but 234hp....
I am RELENTLESS...
R Series Engine Information
Rv8 ACE-360r
Nemesis NXT (building ACE-750r)
Old 10-06-2014, 02:07 PM
Relentless's Avatar
Default Fuel pumps, alternator, front gov pad, and mag sump.
There are several fuel pump options:
Airflow performance and EFii both offer dual fuel pump setups. I have been running the dual ANDAIR fuel pump in my long EZ with 409 and it has worked flawlessly, once I put in 25psi relief value. (Andy is working on internally by-pass version) I like the idea of Dual pumps and the Andair weights only 480 grams. If weight is less of a concern I would go with EFii pumps, they are small package and less $$$$..
Alternator with magnesium case:
You will have to hang one out front....
ECi is just about ready to start sending over forward governor pad cases thus giving you constant speed option and still use mag case....
One last item, we are now shipping with all our vertical sump engines our new magnesium sump. This is a copy of the the old aluminum one but made out of magnesium. Weight 7.5lbs for entire sump! That's 6.5lbs off
I am RELENTLESS...
Rv8 ACE-360r
Old 10-06-2014, 02:29 PM
Greg Arehart's Avatar
So, the $64,000 question (pun intended) is what kind of price point are we talking here? Would be nice to have some idea of whether this is (personally) cost-effective or at least cost-reasonable. I understand that there are a number of things that can change the price, just looking for something ballpark for comparison to other engines (and, yes, I know there is no comparison but...)
Greg
Greg Arehart
N 7965A
Old 10-06-2014, 02:38 PM
DanH's Avatar
Originally Posted by rcpaisley View Post
Negative on the need for an extra alternator with EFII. And only one pumps ever runs at a time. Robert
I beg your pardon. Poor word choice on my part. Strictly speaking, a backup alternator is not required to run the ignition and fuel injection.
Of course, folks who pay $185,000 for a new Carbon Cub SS are, to some extent, paying for confidence. On battery alone, the voltage warning system counts down faster running EFI in addition to ignitions.
Website says 1.2 amps per ignition. How about that pump, ECU, and injectors? And what is the cutoff voltage below which the system no longer operates at 2700 RPM?
Dan Horton
RV-8 SS
Barrett IO-390
