Old 10-05-2014, 05:59 AM
kaurione kaurione is offline
Default Plane Power Alternator problems RV-7
60 amp Alternator and Kit w/OV protection
Part Number = ES ALTERNATOR DELUXE
I have just replaced my alternator with the above Plane Power Alternator supplied by Vans (ES Alternator deluxe).
It has been connected correctly with the white wire going to the indicator bulb and from the bulb to the dc positive bus. The red wire goes to the 5 Amp circuit breaker then to the dc positive bus. The alternator switch was selected on for engine start and remained on until engine shutdown.
Before start the indicator light is on steady.
After start up it behaved perfectly, the light goes out and charges as it should. The loads were put on, Radio, landing lights etc. After about 3 or 4 minutes the alternator warning light flashes on an intermittent basis, maybe at a frequency of about 1 second. Voltage indicates 14.4V but flicks in sympathy to the flashing light.
Any idea?s chaps
Old 10-05-2014, 08:12 AM
RVDan RVDan is offline
Perhaps check the voltage on the red wire at the alternator during operation. If Troubleshooting ref here. http://www.plane-power.com/images/tr...e_Internal.pdf
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 10-05-2014, 08:53 AM
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Old 10-05-2014, 09:12 AM
larryvj larryvj is offline
I just installed the same alternator on my RV7 and it works perfectly. I agree with above suggestion. You have a loose connection from the field supply buss voltage to the red wire on the alternator or a bad regulator/OV protection unit inside the alternator. Check all connections including the condition of alternator field switch and field breaker.
Old 10-11-2014, 02:17 AM
Smile Problem solved
Thank you for all your suggestions.
For those of you who may have similar problems I can now confirm that the original problem was caused by the 14 volt alternator warning light which was rated at only 50mA of current. A very helpful technician at Plane Power said it was important to use a 100mA bulb. The higher current bulb has been substituted and the alternator now works perfectly.
