Yes, it is a 200 hp angle valve. It is the (stupid) model that Mooney's have with both mags inside of a single housing being driven off of one gear.
I get 2200 RPM static, but climb at 1600-2000 feet per minute solo (depends upon the time of year). I comfortably cruise at 160-165 kts (295 to 305 kmh) burning about 33L per hour.
At 2700 RPM, 4000', I get 191 kts (353 kmh).
The prop itself makes the engine VERY smooth and, because it is only 66" diameter, there is a LOT of ground clearance.
Hope this helps
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
