Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 09-19-2014, 02:00 PM
krueger44 krueger44 is offline
Default RV-7A 200HP IO360; Fixed Pitch Prop?
Does anyone know of a fixed pitch prop that can be used on a 200 hp IO360-A1B6? Or is it a bad idea not to use a constant speed prop?
Old 09-19-2014, 02:51 PM
Lucio I-NLCM's Avatar
Lucio I-NLCM Lucio I-NLCM is offline
Default Fp prop
I've almost the same engine mine is 200hp A1A , I chois a three blade Catto prop, that has 70" diameter and 74" pitch , not flying yet, I hope to reach good numbers.
FP versus CS prop always is big dibat, on 200 hp most think the best is CS but our plane are Experimental, so ..... Avery one is free to chois
Gooooood luck
Lucio
Old 09-19-2014, 04:34 PM
Norman CYYJ Norman CYYJ is offline
Get a sensenich prop pitched to 87 inches. Should work just fine. I have a 87 inch pitch on my IO-360 RV 7 .
Old 09-19-2014, 04:39 PM
grubbat's Avatar
grubbat grubbat is offline
Default 180hp +
I have a Catto prop made special for the late Bob Axsom. He ran it on his RV6a and it put out some serious HP and it did fine. PM me if you want specific info. Prop is hanging on the wall waiting for a project.
Cj
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 09-21-2014, 12:25 PM
Flyingleap Flyingleap is offline
Default Tartufo Bianco
Lucio, Yes Lycoming 200hp angle valve engines are on some factory airplanes with fixed pitch, I think ...... wait ...your in Milano ... I don't care what prop gets me there, lets go for those truffles. It's the season!!!
John R Prince
RV-7 want-a-b
Dues Paid for 20
Old 09-21-2014, 02:49 PM
Yes Jhon, is the season, Alba is no more than two hours away, did you see there?
I'm not so crazy for white truffle but I know, it's very nice.
What means RV-7 a-b?
Lucio
Milano Italy
Blue-7
Old 09-21-2014, 03:09 PM
brad walton brad walton is offline
Lucio, call or email Craig Catto and speak with him about pitch. Ive got a 68 x 75 on a 185 hp RV8 that I can spin up past 2700 rpm's. I think a 74 pitch may be too low for 200hp
Old 09-22-2014, 01:02 AM
Default CATTO prop pitch
Brad, thanks for note
your prop is 68x75 mine 70x74 , I don t know if 2" in diameter can make compensation 1" in pitch, in any case When I bought it I asked a prop for high cruise speed , so the answere from Craig CATTO was:
70" diameter x 74" pitch
for IO-360 200hp@2700rpm
Top Speed at target rpm 207-211mph @2750 rpm
4.375" finished Propeller Thickness
Your prop has the same thickness?
How many rpm you have before T/O run?
Lucio
Lucio
Milano Italy
Blue-7
Old 09-22-2014, 05:31 AM
pierre smith's Avatar
Lucio, the "A" models are tricycle gear. Taildraggers don't have a suffix..e.g. RV-7.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 09-22-2014, 06:12 AM
N941WR's Avatar
N941WR N941WR is offline
"RV-7 want-a-b" is American slang for "want to be" which means he wants to own an RV-7 some day.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
