Old 09-12-2014, 03:26 PM
xblueh2o xblueh2o is offline
Originally Posted by DaleB View Post
Dean, I did something very similar on y RV-7. Instead of PVC, I used polycarbonate fluorescent tube shields. Very light weight, easy to work with and transparent so you can see what you're doing when stuffing wire through. I just made some little sheet AL brackets to secure the tubing with RTV and zip ties.
The tube comes in 4' and 8' lengths, so I used one from the root to the aileron bellcrank inspection cover and one from that point out to the wingtip. I figured that was a good point to break the run for wiring to the A/P servo and whatever else might end up getting wired there, like pitot heat.
I used something similar. I found a thin walled polycarbonate tube that was essentially 9/16" OD that fits nicely in the bushing that fits in the 3/4" hole Van's says you can put in the wing. Fluorescent tube light guards is what made me go looking.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 09-13-2014, 12:36 AM
jeffwhip jeffwhip is offline
Sam, are you saying that you removed the plastic bushings that Van's has in place to run wires through and then ran your tubing through that, or are you saying you drilled a brand new hole that Van's says you can drill and then ran your tubing through that?
Also, if Van's is willing to let you drill a new hole would it be better to just remove the plastic bushings in their holes and make the hole slightly bigger?
Old 09-13-2014, 06:27 AM
clutch22 clutch22 is offline
If you are using the corrugated conduit, just remove the bushings already installed and upsize all those holes to 3/4 inch. The conduit will snap through as you pull it through each rib. I thought it was too time consuming and exhausting getting it through all the inboard ribs that are only a few inches from each other.
I'm not saying it's okay to upsize larger than 3/4" diameter, but if I were to do it over again and were to use corrugated, then I think I would find a diameter somewhere between .75" and .81" so that it pulls through a little easier.
Andrew Austin
RV-10
-Flying!
Old 09-13-2014, 06:39 AM
N941WR's Avatar
N941WR N941WR is offline
Try using the search function on the blue bar. This topic comes up rather frequently.
Here is a picture of the conduit run in my wing. Note that it is secured with proseal to keep it from vibrating in place and being cut.
(click to enlarge)
The green and blue pitot and AoA line loops are just temporary until I knew how long they need to be.
When you drill the holes, the conduit doesn't want to go through them very easily and it takes some force to pull it through (and it sound horrible while you do it but it doesn't harm anything).
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-13-2014, 11:09 AM
Thanks Bill!
Old 09-13-2014, 09:36 PM
I drilled the new holes that Van's authorizes and ran the tube through that.
You could go without the bushing. The reason I put the bushings in is it was a simple solution to hold the tube in place and it stops the tube/rib interface rubbing issue. There are other ways to do that but as I said, it was a quick and easy solution.
The pre drilled holes towards the spar I will use for pitot or AOA lines or antenna runs.
Sam
Fuselage underway
N18451 reserved
