Originally Posted by CGameProgrammer
Can you update with the instruction manual when it's ready? I always thoroughly read the manual before purchasing.
Since it is an iEFIS there is no seperate manual. There will only be a seperate installation manual.
The "Lite" does everything a normal iEFIS does, subject to having fewer hardware interfaces.
It uses the exact same binary program code that is used with any other iEFIS.
It uses our new G3 processor, a medical grade Cortex A8 chip from Texas Instruments, effectively a derated industrial spec chip for higher reliability (much in the same way you would derate an engine for higher reliability).
Boards are slowly getting back from our contract manufacturer and we have started assembly. First shipping should be next month. Not much to do on the software as it is the iEFIS software anyway. Just a few differences related to the hardware that can be catered for in the same binary.
The required software additions (mostly code for the AHRS and pressure sensors, audio feed etc) have been completed.
DO-160 has just been done.
Flight testing should start sometime next week.
Rainier
CEO MGL Avionics
