Originally Posted by simatos
Just started install G3X touch into RV7. The display has a spot which would accept the GSU 25 on the back. However since the panel is tilted forward the orientation of the GSU25 would also be tilted. Is anyone aware if one can use this location successfully perhaps by adjusting for the tilt in the configuration set up? Thanks Gary
Hello Gary,
The forward tilt on the instrument panel is no problem at all. As specified on page 12-4 of the Rev. M G3X Installation Manual, the GSU25 may be tilted as much as 30 degs in that axis.
The larger concern is the stiffness of the instrument panel. While the GDU 4XX display has a mounting pad for the GSU25, using it may not result in an optimum installation location for the GSU25 in most aircraft since the instrument panel will have too much flex.
We generally recommend an extremely stiff off panel installation location as a first choice for the GSU25.
Steve
