09-05-2014, 07:27 AM
Oil Cooler
What are my options for an Oil Cooler?
I think I'm going to mount it on the fire wall rather than on the baffles.
Is bigger better? I assume it would be, but I'm not sure. Should I just go with the Van's recommended cooler for the 9a, or is there a better option?
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
09-05-2014, 08:38 AM
-Dan
If you're putting an O-320 in your 9A, the stock cooler mounted on the baffles is plenty. I had to tape off 1/4-1/3 of my cooler to get oil temps up to 190 this summer.
If you mount remotely, it may or may not be as efficient. It's all an experiment from there. However it's easier to block off part of the cooler to remove capacity than it is to add capacity.
Kurt W.
RV9A
FLYING!!!
09-05-2014, 09:03 AM
Depends a lot on what particular engine you're going to have. The standard, small 7-row NDM cooler Vans sells is generally fine for a stock Lycoming carbureted 160hp O-320. That's what's on my RV-6 (mounted on rear baffle aft of cyl #4) and it has always performed adequately even in the summer heat we get here in north Texas. I have seen my oil temps hit 210-220 in a climb however. One friend of mine with an IO-320 on his RV-6 says his 7-row cooler is marginal on his plane on a hot day. He even had to move his from the rear baffle all the way up in front of the #2 cylinder to get enough cooling out of his. Several folks here on VAF have reported acceptable performance with this oil cooler on a normal 180hp O-360 engine, but most of those are not flying in Texas summer heat either.
For a bigger more high performance engine, like another buddy's ECI Titan IO-360 with 9:1 pistons and piston oil squirter nozzles installed in the crankcase, the 7-row was woefully inadequate, within a few minutes after takeoff it was hitting oil temps approaching 240, so we ended up swapping it out right away, ultimately for a high-dollar Stewart Warner cooler that cost almost $700.
In my experience so far with oil coolers, it seems that when you mount one on the firewall and plumb air to it thru SCAT duct, that the cooler needs to be one or two rows larger than one that would be baffle-mounted.
When you do choose your engine, give Pacific Oil Coolers a call ( www.oilcoolers.com) and they can help you with selecting the right size and brand of oil cooler to keep the engine happy flying in Texas summer heat.
Neal Howard
Airplaneless once again...
09-05-2014, 09:04 AM
I have the standard cooler in the recommended position on the baffles. I've been flying off my Phase 1 hours in the dog days of summer (it was 102F last weekend when I landed). Oil temps are no problem. Always around 185-195F.
cooler mounted on motor mount on Maule
My Maule 180 has the cooler mounted on the engine mount with a hose going over to the baffle. Anyone ever try that?
cj
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
09-05-2014, 09:06 AM
Thanks!
I will give them a call. I've got a Superior IO-320 with PMags sitting in a create ready to mount  .
I've been told that the firewall is a better mounting location because the baffles will generally crack with the weight of the oil cooler.
-Dan
Dan Weyant
RV-9A N96KD
09-05-2014, 09:14 AM
Thanks!
-Dan
The baffle will *always* eventually crack from the weight of an oil cooler mounted there.
For your engine, with a firewall-mounted cooler, I'd recommend something like a 9 or 10 row Aero Classics cooler. Put some kind of valve in line with the SCAT duct feeding air to the cooler and you can control the airflow reaching the cooler from the cockpit.
Neal Howard
09-05-2014, 09:30 AM
VAF Moderator / Line Boy
Well, since you used the word "Always".....
This isn't true if the baffles are properly designed to support the cooler. I've been building baffles this way for years now, and have yet to have one crack after a couple thousand hours.
Improperly designed and supported? Of course they'll crack, and I've seen that happen as well.
But it can be done, fairly easily.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
09-05-2014, 09:33 AM
My 6 row Stewart Warner cooler is mounted on the rear baffle. 1051 hours and no sign of cracking. By the way the 6 row SW cooler is more efficient than my stock Vans cooler was.
Bayne
RV-9A N910BJ
RV-7A N227DB
Rans S-19 in process
Reason: signature
09-05-2014, 10:17 AM
I have the stock vans 0-320 oil cooler for my 0-320 d2a on the baffles and wish I had more cooling than it gives me. On 85 degree days I tend to see 200-210F in cruise.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
