Old 09-02-2014, 09:04 AM
Norman CYYJ Norman CYYJ is offline
In Canada we are required to have a gasculator Mike.
Old 09-02-2014, 09:18 AM
flightlogic's Avatar
Trivia... in Canada, it is so cold... your hand cramps up and O's become U's.
Just can't get over the top. Even their loops in RV's are ovals...
Old 09-03-2014, 10:21 AM
bjohnson1234 bjohnson1234 is offline
Oh, one other thing I did was use K&N filter grease to create a better seal between the filter and the airbox to keep any water out
Old 09-03-2014, 10:34 AM
FasGlas's Avatar
FasGlas FasGlas is offline
Humm, I've never seen a FI plane without a gascolator. It's imperative you keep any contaminants out of the injection system.
Old 09-03-2014, 10:38 AM
My understanding (which might be incorrect) is that the gascolator is not effective at trapping water in an FI engine because the higher fuel pressures will just push it through. There are other filters for contaminants in the system. I have had several very knowledgable people, including Don at Airflow Performance, tell me that I should remove it.
Old 09-03-2014, 10:49 AM
spark68 spark68 is offline
Recommended to remove the gascolator...but you still need a fuel filter (or two), usually located before the fuel line penetrates the firewall. This is done to minimize heat absorption.
Mark Curley
RV-6 (under construction)
dues paid 2020
Old 09-03-2014, 10:52 AM
FasGlas's Avatar
The gascolator is the pre-filter, water separator and particle trap before the finger screen in the servo. If you sump the gascolator prior to start up any water and contaminants will be removed ( in theory). There is no pressure in a gascolator, just flow. I'm an A&P and I've never seen any FI engine not have a gascolator. They are in every plane we build. I can't see any reason not to have one. But they certainly aren't required in a home built. I've never seen one fail and I would much rather clean a gascolator then the servo screen and injectors.
Old 09-03-2014, 10:55 AM
The fuel tank drains are the lowest part of the system for collecting water prior to startup. The reason not to have a gascolator is that it transfers heat to the fuel. There is another filter prior to firewall penetration, it just doesn't have a drain for collecting water.
Old 09-03-2014, 11:04 AM
paul mosher
Posts: n/a
Default gascolator
Never saw a gascolator on McDonnell Douglas, Boeing or airbus.
Old 09-03-2014, 11:06 AM
FasGlas's Avatar
Haha.. If that's what you're flying then you're in the wrong forum..
They are gascolators....Not JetAcolators...
