  #11
Old 08-28-2014, 10:07 AM
n468ac's Avatar
n468ac n468ac is offline
Originally Posted by N941WR View Post
While doing a story for KitPlanes some back, I interviewed a guy who made an aluminum hoist for his son. The cool thing was it came apart and would fit in the baggage compartment of his Highlander.
Let me know if you want his contact info.
thanks, the system we are looking into will come apart and fit in the baggage compartment of the RV6, it is fully contained and self powered. So far the total weight looks to be around 36 lbs. We are in the discussions with the manufacture ... our only real hurdle is the system mount on the firewall.
As we work the issues I will post more information for everyone.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 08-28-2014, 10:14 AM
TomVal's Avatar
TomVal TomVal is offline
Any chance of posting a photo of the apparatus that will attach to the pins?
I also like Mike's idea.
Regards,
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 08-28-2014, 10:35 AM
n468ac's Avatar
Regards,
As soon as I get a good picture I will post it.
RV-6A - N468AC
N468AC Web Site
Old 08-28-2014, 10:44 AM
TomVal's Avatar
Another idea...temporarily secure the dual pin bracket through the cowl like a tie-down fitting. Have two bolts running thru the vertical bracket and engine cowl passing into a threaded anchor block affixed to the firewall. Then you would only have two bolt holes through the cowl which could be covered with snap in caps for flight. Then you can detach the pin apparatus for flight.
Tom Valenzia
RV8 (Sold)
Old 08-28-2014, 10:49 AM
n468ac's Avatar
Thumbs up
I really like this idea!!!
RV-6A - N468AC
N468AC Web Site
Old 08-28-2014, 10:55 AM
Low Pass's Avatar
Low Pass Low Pass is offline
This is a better idea. Should be fairly straightforward to do something inside the fuselage/cowling envelope. But to answer your original question, based on the size, shapes and locations of camera mounts I've stuck to my plane, you'll ever know that bracket was there when flying.
Old 08-28-2014, 11:53 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Been thinking about the loads and stresses that something like this will impart to the airframe. Lots of questions/concerns floating around between my ears
Question-------is there going to be a support leg/outrigger that sits on the ground?? or is the entire load going to be cantilevered off the mount attached to the firewall??
A ground leg to carry the vertical load, and a firewall mount to locate the lift, and stabilize the loads seems like it may be a good way to go.
Are you looking to hoist someone up in front of the wing, then swing them around to above the wing, then finally to the cockpit?? If so, the load vectors go all over the place. How many pounds do you plan to lift?? How far from the mount will the arm go??
I would suggest you have an aeronautical engineer take a look at this, and how to transfer the load to the airframe safely. Both safety for the person being hoisted, and safety for the aircraft.
Good luck, homebuilt/experimental aviation at its best.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-28-2014, 01:02 PM
BillL BillL is offline
Is this the one that was behind the Vans tent at OSH?
The base was mounted to the bulkhead behind the seat, and carbon fiber tubes were sections that fit within each other. A skyhook hung out of the top and had an electric hoist. The Aluminum section was a ball bearing pivot.
Yes, Mike, it picked up the passenger from a wheel chair, hooked onto the hooks you see hoisted. It then perfectly fit right over the seat. I did not see it in use, but the owner used it for a paraplegic passenger. It did not look very heavy and he erected it from the baggage compartment in a few minutes with no tools.
That section of the fuse forward is pretty torsionally stiff. Think of the weight just on the steps.
Bill
RV-7
Lord Kelvin:
Old 08-28-2014, 01:18 PM
n468ac's Avatar
--> not sure at this point ... but I've too though about this
--> correct in front of the wing, swing over the wing, then into the cockpit. the mount will be braced across the front of the firewall, maybe in a "<" v connecting to the far side engine mounts. The arm will be between 45 and 54 inches long to allow for the lift from a wheel chair and then lower into the seat. Lifting weight will be 180lbs.
--> point taken
RV-6A - N468AC
N468AC Web Site
Old 08-28-2014, 01:19 PM
n468ac's Avatar
Ours will be a different design, but his setup got me thinking! I've also talked to that gentleman last week and have gotten more pictures from him.
RV-6A - N468AC
N468AC Web Site
