Old 08-27-2014, 08:33 AM
java's Avatar
java java is offline
482 Registered in Canada under the common name "Van's", so about the same as Australia.
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 08-27-2014, 11:56 AM
Ralph Inkster Ralph Inkster is offline
Default More Canadians enjoying RVs
Data fields aren't too consistant in Transport Canada's web search... I figured we had more so searched some alternate possible model names & got the total up to 394 & know there are more RVs still because for one Transport didn't list a single RV-8A... I've flown one! My quick results
RV-3 - 19
RV-4 - 76
RV-6&A - 128
RV-7&A - 60
RV-8 - 25 plus the 8As out there somewhere
RV-9&A - 68
RV-10 - 17
RV-12 - 1 !!!
Also a number of builders chose to call their planes other than the Vans model #, example 'Foll-6' so is impossible to know the true number of RVs in the Great White North!
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 08-27-2014, 11:57 AM
See number increasing even as I type!
Ralph
Old 08-27-2014, 12:41 PM
DHRYCAUK's Avatar
DHRYCAUK DHRYCAUK is offline
With a little creativity with the search engine on the transport canada website I got the following for Canada
RV-3 - 19
RV-4 - 71
RV-6 - 92
RV-6A - 71
RV-7 35
RV-7A - 56
RV-8 - 43
RV-8A - 5
RV-9 - 6
RV-9A - 56
RV-10 - 24
RV-12 - 1
RV-14 - 0
Total - 479
Central Alberta, Canada
RV-8 Bald Eagle (Purchased April 2014)
Old 08-28-2014, 08:40 AM
prkaye prkaye is offline
Interesting to see the RV-6 has the highest number by a fairly significant margin!
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-29-2014, 01:00 PM
flyvans.com flyvans.com is offline
dug up a few figures for Switzerland:
18 active RV's on the swiss register, trend is pointing upwards :-)
Breakdown by model (flying / under construction):
RV-12: 2 / 4
RV-10: 2 / 4
RV-9A: 0 / 0
RV-9: 0 / 0
RV-8A: 0 / 0
RV-8: 3 / 6
RV-7A: 3 / 6
RV-7: 2 / 6
RV-6A: 2 / 0
RV-6: 1 / 0
RV-4: 3 / 2
RV-3: 0 / 0
about 8 million population.
1462 light airplanes (MTOM < 2.2t).
approx 8700 fixed wing pilots (PPL + CPL + ATPL, without HEL)
1 RV per 444'444 inhabitants. ;-) (long ways to go, factor ten, to get near U.S. or australian levels!)
1 RV per 480 pilots
1.25% of small planes are RVs.
we're trailing a bit, i suppose ;-)
to look beyond RVs:
about 6 pilots per light airplane, although a significant portion of airline pilots (2200) likely do not participate in recreational flying.
1 light airplane per 5470 inhabitants.
230 experimentals, by definition in the < 2.2t category, apprx. 16% of light airplanes.
Bernie Daenzer, Alex Lichtensteiger
www.flyvans.com
RV-7A
S/N 72072, Flying!
HB-YMT (Switzerland)
Old 08-29-2014, 01:43 PM
rgmwa rgmwa is offline
Looked up our friendly neighbours over in New Zealand just out of curiosity: 62 RV's (plus a few Rockets), population just over 4.5 million (it would be higher except that all the others are here ), so about 1 RV per 72,000. Pretty respectable numbers for a small country surrounded by water.
rgmwa
RV-12LR 912ULS
120346
Old 08-30-2014, 01:41 AM
Warbo's Avatar
Warbo Warbo is offline
I think what would be interesting would be to compile a list of all the countries that have an RV on the register. Has this ever been done? I wonder how many really out of the way places have an RV flying.
Ian Warburton
Canberra, Australia (the nation's capital)
RV-7A #74351 Empennage finished (including the tips)
RV-8 VH-DAF (part-owned)
PA-28-140 VH-IAL
Working on wings and fuse
https://rv7warbo.wordpress.com/
"A journey of a thousand miles begins with a single step."
Old 08-30-2014, 02:56 AM
pgroell's Avatar
pgroell pgroell is offline
Default France
In France, 55 RV's on the national registry (10 RV4, 11 RV6/6A, 15 RV7/7A, 13 RV8/8A and 6 RV9A).
There are around 70 RV's still being built.
Pascal
RV-7A #72588 - F-PSGA
VAF #484 - Donated 2020
Flying
www.notreavion.net
Old 08-30-2014, 04:52 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
And the Vans hobbs meter is only as accurate as the number who bother to tell them they are flying.
It is likely to be a LOT more. You would need to add up the registers of all the likely countries.
About 500 here and it seems like another 500 in the build phase?.lotta kist have come down here in the last few years.
David Brown
