Old 08-23-2014, 08:18 AM
Kitfoxbill Kitfoxbill is offline
Default RV-7 Carbon fiber Panel wrap
First pic of my panel back from Aircraft Wraps. Great job by them. Yes....
[IMG][/IMG]
[IMG][/IMG]
William Bennett
RV7 almost finished
RV8A for sale.
Old 08-23-2014, 08:29 AM
Sig600 Sig600 is offline
Cool!
Filler...
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 08-23-2014, 11:47 AM
William William is offline
Hi William your panel looks really good! Do you know what system was used for the labeling? I've been having a hard time getting the labeling to stick to my carbon fiber wrap pannel because of the texture.
Bill
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 08-23-2014, 05:07 PM
AircraftWraps's Avatar
AircraftWraps AircraftWraps is offline
William,
Thank you for allowing us to create a fully printed panel for you. I think the carbon fiber on your panel came out great! It took a little sizing and tweaking to get the fiber weave sizing correct.
We are able to print pretty much ANY background. Wood, stone, carbon fiber, graphics, etc.
For the other poster."Labels". Everything is printed complete. Switch labels are printed into the wrap and can be ANY font, style, size, color, etc. You'll notice the cool yellow striped markings to his Panel. That is also printed into the wrap.
We created a File and emailed William a couple of proofs that he was able to make adjustments to before final print. Once he gave his approval... it's digital and printed exactly as he approved.
Regards,
Scott
www.AircraftWraps.com
Have a paint price? Send it to me and see what we can do!
Please visit and Like us on Facebook.
https://www.facebook.com/AircraftWraps
Check our our Instagram photos - here
Please note, emails sent to hotmail are being delivered to Junk .
Old 08-23-2014, 05:15 PM
Example of adding a revision:
Adding a cool yellow warning label and also increasing the Fiber weave size to give correct dimensions:
Old 08-23-2014, 05:21 PM
Brantel's Avatar
Brantel Brantel is offline
Always interested in possible new panel stuff.
That looks great.
What was the cost of that wrap?
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-23-2014, 07:22 PM
That looks great.
When emailing for a quote: Please include "Panel Wrap" in the subject line
We have a couple of options.
Send us a detailed plan like this: (we are currently working on a "panel builder" for the website to eliminate the need to mail in.) If you already have a digital format of the panel we can use that.
From there we can:
1. RV4/8 Single panel: $190
RV6/7/9/10/14/: $250
(includes the printed wrap and design work).
Printed to your specifications and we will mail it to you. You will install it yourself. If the panel is not cut yet, this should not be a problem and we can even put little "bulls-eyes" to drill through for switch alignment. If your panel is already cut... It might be a little challenging to do correctly for a novice.
2. RV4/8: $280
RV6/7/9/10/14: $380
(Includes the printer wrap, design work, and installation)
Mail us the cut or uncut panels with the diagram/file discussed above and we will professionally install the wrap for you.
3. We can order the panels directly from Vans and install an uncut/with bullseyes wrap to the uncut panels. You would receive the panel complete to your specifications. This would work for customers that don't want "down-time" removing the existing panel till the AircraftWraps panel arrives.
Please email for a quote
4. We can order directly from Vans and CNC the panel to your specifications followed by the AircraftWraps panel wrap.
Old 08-25-2014, 11:36 AM
walkman's Avatar
walkman walkman is offline
I'm interested in the material used for the panel wrap.
I have tried out, and liked, a sample of the 3M carbon fibre look vinyl. The 3M stuff has a pretty realistic surface texture.
Is this wrap the same stuff? Or is it a flat 2D print on a flat untextured material?
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 08-25-2014, 01:03 PM
Default Wrap material
This is a smooth to the touch. The pattern and lettering is printed onto the material.
William
RV8A for sale
RV7 finishing.
Old 08-25-2014, 01:06 PM
Sid Lambert Sid Lambert is offline
What technology are you using to print to the vinyl? Are you laminating it with a matte over lam after?
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
