Go Back   VAF Forums > Regional Forums > Canada
  #21
Old 08-14-2014, 01:08 PM
kamikaze kamikaze is offline
A second pair of eyes. The person is signing along with you that the controls are operating as they should (are not reversed, have full range of motion, are smooth, etc.). They therefore must witness all this and also be satisfied when signing.
J.F.
Sling 4 empennage kit on order!
Future EAA 245 Member (Hopefully)
Current Piper Warrior PA-28-151 Owner/Pilot
Ottawa, Ontario, Canada
http://www.sling4.ninja
Old 08-14-2014, 02:40 PM
flyboy1963's Avatar
Default see Vern's link....
http://www.md-ra.com/en/docs/C100_Co...s_20130312.pdf
It is dated March 2013, and says, 'effective immediately' but does not reference a specific change to the CAR's, so we are still a bit in the dark there. Since 2010? Let's just say that very few guys I know are aware of this.
at least this MD-RA version says "...the second person signing must be educated so that they understand what they are witnessing."
....very broad & grey, putting the responsibility on both the signee, to be educated, and the owner, to ensure they qualify.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 08-14-2014, 08:58 PM
The table says "(amended 2010/12/30)" for the section on flight/engine controls, so it's been there at least that long ... the link to the previous version is broken
I've done this in real life, and it really isn't that big a deal ...
As for not knowing, I'm going to guess this community, by its nature, maybe doesn't follow the evolution of the CARs as closely as the certified world does ... my AME certainly knew all about it a year and a half ago, and I could check my logs, but the previous work on my controls was done right around 2010, and I'm pretty sure I had a double signature then.
I imagine AMEs get notified of these things ...
I wonder f there's a way to subscribe to get notified of CAR changes ...
J.F.
Old 08-14-2014, 09:01 PM
Norman CYYJ Norman CYYJ is offline
It costs money and it is up to us to stay current.
Old 08-15-2014, 08:42 AM
Lupin Lupin is offline
The requirement for dual signatures has been around for ages. I obtained my AME license in 1997 and that requirement was in the Air Regs. It is now in the CARS.
The context is different but here is how things are done where I am employed. I work for a major airline in Canada, as such, we operate with a Transport Canada approved control manual. For us, the independent check process is well defined. First choice for an independent check is an appropriately rated AME, second choice is a non rated AME, third option is for a pilot to perform the independent check. If a pilot or non endorsed AME does the certification, the system is to be re-certified at the next base where an appropriately rated AME is available.
Keep in mind that requirement is there due to numerous past accidents where controls were reversed with often catastrophic consequences.
Here is what you are looking for:
The independent check need not cover the same range of detail as the check leading to the maintenance release. However, as a minimum, it must include an inspection for correct assembly and locking of any parts of the system disturbed by the maintenance performed, an operational check for proper sense and range of operation.
http://www.tc.gc.ca/eng/civilaviatio...s-c010-557.htm
Old 09-13-2014, 07:29 AM
CDNRV7's Avatar
CDNRV7 CDNRV7 is offline
Location: Canada, well not really at the moment, but where I will build.
As a helicopter pilot I have been signing "Dual inspections" when required since 1978, and I'm sure this requirement was there long before that. You would not believe the amount of times I have seen gross errors in that time, and not by incompetent AME's, just ones who were working in very adverse conditions.....no one is infallible, we all make mistakes.
Still in dream phase, just starting to organize the shop
for my retirement RV7 project
Dues Paid for 2015
