Old 08-12-2014, 08:18 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Default Alternative cabin hot air source...
...I'm not talking about the pilot or passenger
As I was pondering my #4 cylinder temperature/oil cooler temperature/plenum & cowling delta-p, I thought it might be interesting to route the exit air from the oil cooler to the cabin heat valve (instead of from the exhaust shroud).
I'm using a 3" duct to feed the oil cooler currently, and was going to change it to a 2" based on temp & performance data I have.
Has anyone else done this?
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 08-12-2014, 08:25 AM
vic syracuse vic syracuse is online now
Super Moderator
Default Not hot enough
Heat from the oil cooler never seems hot enough to warm the cabin.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 08-12-2014, 09:04 AM
rocketbob's Avatar
http://nickugolini.com/Website/Oil%2...%20Article.pdf
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 08-12-2014, 09:53 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Originally Posted by rocketbob View Post
What a great idea!!!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 08-12-2014, 06:50 PM
rzbill's Avatar
rzbill rzbill is offline
Nice article Bob.
BJ,
We had an unusually cold winter this past year and I was REALLY uncomfortable on two flights. That was with the standard kit setup for RV7A with IO-360-M1B. (There is a new one released this spring by Vetterman. I have the older style)
I added a second muff on Cyl 4, hooked in series with the original muff on Cyl 1 and fed the pair from a manifold on the back of the oil cooler. It did improve the heat but not as much as I expected. Possibly enough that I am done fooling with it. I can't imagine the oil cooler air by itself being nearly warm enough.
Bill Pendergrass
ME/AE '82
Old 08-12-2014, 07:14 PM
BillL BillL is offline
Hmmm. It probably depends on which engine (jets or not) whether there will be enough oil heat in winter. Don't many people completely block off the oil cooler to keep the temperatures up in winter? If so, the colder it gets outside the less heat is available from the oil. 1200-1300F is always available from the exhaust pipes.
Disclosure - I have the AWI exhaust and they have welded studs on on the exhaust pipe under the heat muff. I am counting on them to provide enough heat from one muff down to at least zero F. I also have heated seats.
Maybe AWI would add them to your pipe for a nominal charge. They are resistance welded on with huge threads too.
I suppose if things get worse, I can get heated underwear like Dan H
Bill
RV-7
Lord Kelvin:
Old 08-23-2014, 02:58 PM
lllewis45 lllewis45 is offline
Default Cabin heat
I purchased an RV-7A two years ago and read with interest all the folks complaining about not enough heat in the cockpit. I live in the Denver area and take my RV to AZ in the winter to have it with me in my other RV---Winnebago. Last year I flew it down to Coolidge, AZ on Dec. 23rd when Colorado was having some very cold weather. Crossing the Sangre De Cristo mountains and above some show showers, I flew for probably an hour between 16 and 17,500' with an OAT of -35 C. I was very comfortable in just a light jacket. The builder I purchased it from lived in Wisconsin and he has fabricated a plate to place over the opening in the upper rear baffle that goes to the exhaust heat muff, reducing the scat hose opening to only 5/8 ". I suspect that dramatically increases the temperature of the air going to the cabin because of reduced airflow through the heat muff.
My problem with cockpit temperatures is keeping it cool enough at lower altitudes in the summer, not warm enough in the Winter.
LL
Old 08-23-2014, 06:22 PM
JAT JAT is offline
I also live in Colorado, so I put some extra effort into the cabin heat. 1. I started off with heated air coming from the bottom of cylinder four (the curved section of the baffle). I welded a 1-1/2" aluminum tube to the curved section and ran a scat tube from there to the heat muff. 2. I changed my cabin side controlled valve to a firewall side controlled, so I could hook a scat tube on the inside of the cabin. 3. I ran a scat tube to the plastic valve and placed it even with the instrument panel, so it can be aimed toward the back cockpit or up at me. 4. I bought two wide mouth baby bottle nipples to cover the fresh air valves to stop unwanted cold air. 5. I sealed the spar braces on the side walls, RV-8A, but think the gear towers on the RV-8 should be looked at also for leaking air.
Even at 20 F or colder I can't hold my hand in front of the valve for more than five seconds. It is that hot and both cockpits are warm. At cruise settings the heat muff can only generate X number of BTUs. The warmer you raise its incoming air the higher the cabin temp will be. Bringing the hot air closer to the crew will also help them feel warmer.
BTW, on my current project I have converted my old cabin side valve to a firewall side by moving the actuator arm to the opposite side of the valve and then riveting a flange, so it goes through the firewall into the cabin. This is easy to do and can save you some money.
On my current project I spent some extra time fitting 1/16" inch rubber sheeting over all the openings (wing attachments, flap rod, rear spar, etc.).
Also, always fly in clothing that you could stay outside overnight comfortably. Hope this helps.
Jim
Old 08-23-2014, 07:25 PM
rzbill's Avatar
LL
LL,
I was very specific about my setup because there are differences in what is available to builders depending on the engine.
So....one important aspect is whether the sump is a vertical intake (carbureted or injected) or horizontal intake (injected only). A second aspect is whether the craft is an A model or not (I see yours is an A). The exhaust designs and available spots for heater muffs are considerably different. It is my understanding that the heater muffs on the carbureted exhausts are much better than the puny unit on the horizontal injected exhaust for A models. Can you specify what is on your purchased craft?
Bill Pendergrass
ME/AE '82
Old 08-24-2014, 08:48 AM
CDNRV7's Avatar
CDNRV7 CDNRV7 is offline
Location: Canada, well not really at the moment, but where I will build.
LL
But isn't it important to have a lot of air passing thru the muff heater to avoid overheating and failure? That is why the heater box has 2 positions, one directing the flow into the cabin, the other dumping overboard so you never stop the flow.
I am really interested in the articular about using engine oil for heat, really killing 2 birds with one stone, not only having safe cabin heat but also maintaining a constant oil temp for the engine. Muff heaters and CO have always made me nervous.
Other than possibly an oil line leak spraying hot oil into the cabin, does anyone see a down side to this idea?
