This was a retrofit - replacement EFIS, so I wanted to keep the wiring the same.
You can see where the old Hall effect one was on the firewall.
It ran for 400hrs no problem. Current setup has 100 hrs.
Ideally yes these things should be aft of the firewall, but if you have it in the B lead, it has to be firewall fwd I guess.
