08-04-2014, 04:46 PM
Ground adjustable prop
Is anyone flying the (I) O-320 with the Sensenich Composite Blade ground adjustable prop? If so, are you happy with it? Are there RPM restrictions?Thanks.
08-04-2014, 04:48 PM
Smoother, lighter and slightly faster than the Sensenich metal fixed pitch prop. NO RPM restrictions! What's not to be happy about?
YMMV
Bill
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
08-04-2014, 04:53 PM
I'm flying it on my RV-6. I'm very happy with it so far. The only rpm restriction is the 2700 rpm redline, same as the engine itself. It's taken me to Oshkosh and home twice now, plus a trip over the Rockies to Johnson Creek Idaho and back home too.
Neal Howard
Airplaneless once again...
08-04-2014, 06:51 PM
How easy is it to change pitch? 5min? 30?
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
08-04-2014, 07:39 PM
Most of my flying has been cross country. It seems to me this Sensenich ground adjustable prop would be perfect for me because of that. I have not chosen my engine yet. It would be nice if Sensenich made a prop for a 360.
08-04-2014, 07:57 PM
Try whirlwind
http://whirlwindpropellers.com/aircr...ade-propeller/
Whirlwind propellers has a ground adjustable prop for 360.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
08-04-2014, 08:06 PM
The GA composite prop for the 360 was recently released. I'll be using it on a Superior XP 400. The engineering staff evaluated this application and said it will be fine since my rated hp is 215 and the prop is rated at 220 max hp. Various finishes are available including clear to show the carbon weave which is how I ordered mine. Backlog is around 1 month....mine should arrive in another couple of weeks or so.
Chris Engler, Greene, NY
RV 8 Completed and Flying (N184CE), Showplanes Fastback and Cowl, Barrett IO-360; Dual GRT 10.4 HXr
Kitfox 7; Rotax 914, Built and Sold
VAF donation gladly paid through January 2021
08-04-2014, 08:10 PM
20-30 minutes for a pitch change on the Sensenich. I personally don't advise reusing the Nordlock washers more than 3 times. Zoro Tools sells a set of 8 Nordlocks for about $18.
Sensenich does have a version of this prop now for the 360 engine.
Neal Howard
08-04-2014, 08:18 PM
20-30 min doesn't sound too bad. How often do you change it? Is the difference marked enough that you might flip it to 'climb' on a high DA day?
I'm trying to slowly figure out where I sit in the FP-GA-CS range. The GA seems like a reasonable middle ground, though some of the electric CS sound interesting too.
08-04-2014, 08:25 PM
I changed mine from #5 to #6 for colder weather flying last winter but put it back to #5 for my Johnson Creek trip earlier this summer. I've left it there for now and it's a good compromise for climb and cruise. I may just leave it there.
BTW, here's the thread showing pics of my installation http://www.vansairforce.com/communit...d.php?t=102431
Neal Howard
