  #51
Old 07-25-2014, 11:31 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I've been experiencing this issue and even went so far as to order some of the main leg stiffeners to install. As I was working my way through my annual I found my nose wheel was now only taking about 18 pounds of force to rotate versus the 26 lbs Vans recommends in the plans. Those belleville washers definitely smoothed out (I had pre-sanded them a bit too). I also found my nose wheel was under inflated as well. Hopefully that will be the shake I've been feeling.
Just to go back to what Mike started the thread with, be sure to check out the mechanics of the wheels to see if something else is going on.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-26-2014, 02:49 AM
rleffler's Avatar
rleffler rleffler is offline
I had the shake happen twice.
Then I too noticed that the nose wheel torque had dropped to about 10lbs. I tighten it up to about 30lbs. I haven't had a shake incident since.
I also believe that the Planearound spacers on the wheel bracket help tremendously in damping any oscillations over the plan fabricated spacers. If you don't have them installed, I would highly recommend them.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 07-26-2014, 03:07 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Are you greasing the Belleville washers?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-26-2014, 08:56 AM
The only grease in that area was done via the zerk fitting after assembly. When applied it will ooze out between the washers. So in that way yes, they are greased.
RV-10
N928MT
Build Project Site
Old 07-26-2014, 10:37 AM
az_gila's Avatar
Smile
The Bellville washers on my Tiger are specifically called out for a grease application (Aeroshell #6 or equiv.) every 100 hours.
To apply the grease, the nose gear swivel must be removed, the washers cleaned and re-greased, re-assembled and the break out torque adjusted.
Since the system is identical to that on the RVs, it seems like a good maintenance practice.
Does Vans provide any specific maintenance instructions for the Bellville washers?
Gil Alexander
Old 07-26-2014, 07:03 PM
No guidance from Vans that I know of. I think one of the reasons this happens is that there is nothing in the plans about greasing the zerk fitting up there, so most people are setting the breakout with a dry configuration and when its greased later on, the breakout is greatly reduced.
RV-10
N928MT
Build Project Site
Old 07-26-2014, 09:19 PM
9GT's Avatar
9GT 9GT is offline
I notice a shopping card shimmy today during taxi for take-off. Time to investigate.
David C.
Howell, MI
Old 08-08-2014, 08:17 PM
Just to follow up, after increasing the breakout force on the belleville washers (post greasing), my shimmy is now completely gone. I did not install the main gear stiffners or anything else. So I suspect my problem this whole time was just from the breakout being lowered after greasing.
The plans really should indicate that the setting should be made AFTER greasing the joint.
RV-10
N928MT
Build Project Site
Old 08-08-2014, 08:22 PM
Jesse's Avatar
Jesse Jesse is offline
It will likely need to be tightened again, at least once. You may also need to add spacers under the hat on the top of the nose gear shock strut.
Jesse Saint
Old 03-27-2016, 02:31 PM
Kellym Kellym is offline
As a result of reading previous threads, and the classic 15-30kt shimmy on my -10 that is otherwise ready to fly, I checked the torque of the gear leg socket bolt. Right at spec, BUT, I could turn the bolt head with the nut turning right along with it. The stock bolts with plans called for 1 washer plus nut was allowing the nut to bottom on the threads. Installed an additional washer and retorqued. Substantial reduction in shimmy now. I wonder how many -10s do not have adequate torque on that bolt because the nut is just barely bottoming before torque is achieved. It looked like it was fine with torque wrench, until I noticed the bolt wasn't squeezing and could be turned. I also checked the bolt for overall and grip length and it was on spec.
Kelly McMullen
A&P/IA
EAA Tech Counselor
KCHD
RV-10 40866
