Old 07-24-2014, 08:48 AM
N402RH's Avatar
N402RH N402RH is offline
Default Advanced Flight Quick Panel System
Advanced Flight Systems (AFS) announces the Quick Panel System, a line of complete pre-built avionics panels. Starting with the RV-7/9, and with the choice of VFR or IFR avionics, installing an aircraft?s modern avionics and electrical system is no longer a time consuming, complicated and frustrating experience. Each panel includes a well-engineered instrument panel that is professionally wired, configured, tested and ready to install. All avionics, including the aircraft?s autopilot servos, trim servos and lights are all cleanly wired to the new Advanced Control Module.
This new Advanced Control Module, the heart of the Quick Panel System, integrates circuit protection, panel dimmer controller, flap controller, trim controller, Wig-Wag controller, EFIS networking and a panel switch interface. Rob Hickman, President of AFS, states that "The combination of the new Advanced Control Module and production line manufacturing techniques results in a lower cost yet higher quality panel. It saves the builder hundreds of hours in wiring, crimping, and troubleshooting."
Two panels are being displayed at Oshkosh Airventure 2014, both for the RV-7/9 and both at a special price of $19,995. One has the AFS AF-5600 Touch system, and the other the Dynon SkyView D1000T Touch system. Both panels feature large dual-redundant displays, COM radio, stereo intercom, transponder, ADS-B traffic and weather, ADAHRS, Angle-of-Attack, 406 MHz ELT, autopilot controls, ignition and all other switches and audio jacks. The IFR version adds an IFR GPS navigator, second ADAHRS and a Dynon EFIS-D6 as an independent backup. The front panels are powder coated and silk screened for a professional finish.
Panels will soon be available for many other aircraft.
Advanced AF-5600 RV-7/9 Panel
Advanced Skyview RV-7/9 Panel
RV-7 Installation with Advanced Control Module
ADVANCED Control Module
? 22 Channels of Circuit Protection
? Panel Dimmer Controller
? Flap Controller with Positioning
? Trim Controller
? Wig Wag Landing Light Controller
? SV Network Hub
? EFIS ARINC interface
? Panel Switch Interface
Rob Hickman
Advanced Flight Systems Inc.
N402RH RV-10
Old 07-24-2014, 09:04 AM
DeltaFox DeltaFox is offline
Very interesting Rob. Are you going to be offering the components or the control modules separately?
Dale
RV-9A Airworthiness certificate Oct 2017,
first flight 11/18/17, testing completed Mar 2018.
Now free to move about the country.
http://dalesrv.blogspot.com
2020 Dues Paid
Old 07-24-2014, 09:11 AM
Jrskygod Jrskygod is offline
It would be awesome if that control box was available separately. I'd buy one tomorrow.
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 07-24-2014, 09:41 AM
vlittle's Avatar
vlittle vlittle is offline
You forgot the seat warmers and expresso machine... was it your intent to give up the Canadian Market?
Cheers, Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 07-24-2014, 11:24 AM
N402RH's Avatar
Cheers, Vern
Vern,
We would never forget about the Canadian Market..
Get off the Chesterfield, head to your local ABM for some Loonies so you can come see it on Monday at Oshkosh.
And yes you should be able to plug your expresso machine into the Aux circuit, Eh.
Link to the Quick Panel System Literature
http://advanced-flight-systems.com/p...literature.pdf
Rob Hickman
N402RH RV-10
Old 07-24-2014, 11:39 AM
N402RH's Avatar
Default IFR Panel Information
Advanced AF-5600 IFR Panel
Advanced Skyview IFR Panel
and the best part.........
$34,995 for either panel (configured, tested and ready to bolt into your RV-7 or RV-9)
Rob Hickman
N402RH RV-10
Old 07-24-2014, 11:58 AM
DaleB's Avatar
DaleB DaleB is offline
The only thing that appears to be missing is one item that I now consider mandatory for any vehicle...
USB power ports. Almost every single personal electronic device we have now uses or can use a USB port for power. Cameras, cell phones, tablets, bluetooth headsets, portable GPS, all of it.
Aside from that it looks pretty nice, and reasonably priced if you want dual screens.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 07-24-2014, 12:06 PM
JennyH's Avatar
JennyH JennyH is offline
There is a panel mounted 12V accessory power plug into which you can insert a USB power adapter.
Old 07-24-2014, 01:18 PM
tdhanson tdhanson is offline
Is there a configuration of the Advanced Control Module that would integrate with a Vertical Power electronic CB system that does not have the fuses?
Tracy
Old 07-24-2014, 01:19 PM
vlittle's Avatar
Originally Posted by N401RH View Post
Vern,
Rob Hickman
N402RH RV-10
I already gave all my money to Dynon, sorry. I did find one thing, however, that you didn't integrate... A Stick Shaker.
You can see the one I designed for MakerPlane at the EAA Innovation Center at Oshkosh. Pretty well all of the other products I have designed over the years just got subsumed by your box. Between you and Dynon, there will be no opportunity for me to innovate anymore. That's no fun.
V e r n. ====
RV-9A complete
S-21 wings complete
