  #11
Old 07-10-2014, 05:50 PM
paul mosher
Posts: n/a
Default stc
The mogas stc covers engines that were designed to run on 82 octane avgas.
Old 07-10-2014, 06:56 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Regarding vapor pressure, a little 100LL in the mix goes a long way. Ratios of as little as 1 part 100LL to 8 parts mogas have a significant effect.
More details on this thread.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 07-10-2014, 07:55 PM
Bruinpilot Bruinpilot is offline
It's one of those things... I really want to run mogas and there are those who seem to have good luck doing it, but I read and see too much information that scares me. For now it looks like 100LL. Thanks for all of the good info and the links.
Old 07-10-2014, 08:37 PM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
That's exactly how I feel. I know you can save an average of $50 per fill up but I'm flying in a $100K machine, do I really care about $50 per fill up and if I do, should I be flying? I'm loving the Experimental world so far but still having a hard time with some of the justification that I see others make, but no disrespect to anyone and not judgement on anyone, it's just not for me. To each it's own, fly safe and enjoy
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
Old 07-11-2014, 05:49 PM
JimWoo50 JimWoo50 is offline
Default On my 3rd tankful
For my 0-320 with a pmag and have noticed absolutely no difference in performance or temps. ETOH free at Starke County IN, KOXI, 91 octane.
Used same fuel in a 0-300 powered C-172 for years never any issues.
I like saving $50. per tank it adds up and gives me somewhere to go (20 min.) when I just feel like going for a ride. Last time it was $1.57 per gal. Savings.
I hope to fly west soon and you can believe I plan my route to a degree via Mogas availability. First stop David City NE, not even that far out of the way.
After that......?
Jim Woolard C56
N9855J RV-6 Donated 2020
Old 07-12-2014, 03:26 AM
PIN 37 PIN 37 is offline
Hope that helps.
I am not very smart Dave, are you saying dont use mogas at all? and is mogas in Oz the same as mogas in the US?
Should we not use mogas at all?
Can I say that I consider fuel to be one of the cheaper things in aviation and would not consider using mogas in lieu of avgas if it were available, however this may not always be the case.
Phil
LAME (Aust)
RV7 99% finished
Old 07-12-2014, 06:37 AM
L'Avion's Avatar
L'Avion L'Avion is offline
Default Find ethanol free mogas - link
http://pure-gas.org/
Old 07-12-2014, 07:28 AM
There is much conflicting verbiage on the subject of mogas and ethanol.
I don't like ethanol because it can be corrosive if it comes in contact with material not designed to withstand it. But to say it causes vapor lock may not be true.
I bought and tested E85 for vapor pressure a few years back and it came in almost as good as 100LL. Also, there are Lycomong powered aircraft flying with 100% ethanol.
There's an element of politics when ethanol is discussed and that really muddies the water.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 07-12-2014, 08:01 AM
N427EF N427EF is offline
Default 20 year old wifes's tale
Concerns about corrosion issues over ethanol is simply no longer an issue.
This obsession with ethanol free gas is all based on the catastrophic effect of early ethanol blended gasoline and I do agree it was a very valid concern.
Phase separation:
Highly unlikely if you keep your fuel tanks closed and fly a lot with fresh fuel.
Even less likely to happen in mid flight.
Vapor lock:
Design a fuel system to prevent it:
Either fuel pumps pushing fuel to your fuel controller or constant flow return,
both work, different concept. Fuel injection preferred, High fuel line pressure
is your friend when it comes to vapor lock.
All fuel system components must be ethanol tolerant.
AFP fuel injection system takes care of that.
Rubber o ring on tank drain replaced with Viton o ring ( 10 cents)
Mechanical fuel pump is the only wild card in my system and the only reason I carry Avgas. No one will tell me if the rubber components in that pump are ethanol compatible and I choose to park the aircraft with avgas in the system so as to minimize exposure of those rubber parts to ethanol. I do know from unnamed sources that rubber used in those fuel pumps is not a concern for ethanol. In todays litigious world one is better off listing a thousand things that can go wrong and not mention what actually works.
As to flying on mogas with ethanol:
I have tested as many scenarios as I could think of using mogas only and in
2 years and 260 hours of flying have not seen or noticed a stumble, burp, or anything else running the engine throughout it's power envelop in any and all conditions.
Many of us are using mogas with ethanol some without any modification but most are smart enough not to spread it all over the internet
From an engineer at the forefront of development:
BillL
Originally Posted by ronschreck
<snip> BTW, are there not some corrosion issues with running ethanol-blend fuel?
Since this thread has been revived . . .there are real facts and data behind elimination of modern ethanol corrosion issues. They were very real and very bad. It is true that they have been eliminated at the manufacturing plant.
The early ethanol plants (circa 1994) were not required to have a continuous monitoring system for acidic content. Cargill and ADM made 90% of all ethanol as an additive at that time. The manufacturing process adds acid to accelerate the mash fermentation process (like the old batteries in hillbilly stills) then a water wash process removes the acid. Some plants did not have good controls and allowed the acid laden ethanol out on the market. My engineering group worked with Cargill and ADM to propose, and get, the ASTM testing standard modified to make it a continuous process measurement rather than the batch process being used. This change pretty much eliminate all corrosion due to the ethanol content over the following 12 months that the standard allowed for compliance.
More background: At the time (mid 1990's) my engineering group was developing catalysts for large diesels that sprayed pure(denatured) ethanol in front of a catalyst bank to reduce NOx by 90%. We had field testing sites that purchased 10,000gal tanks of ethanol. The first one was ok, but then we started to eat up everything. Pumps especially. We had a 5 gal can of the stuff shipped back to us and it dissolved the chrome off the pull out spout of the 5 gallon can, and in the process of eating the container neutralized itself. Struggling for a while, I sent a guy with a glass container and brought a sample back. It was 500 times over the acid limit of the standard. yes, five hundred. So- the old tales of corrosion were true and were nearly impossible to trace. The large batch sizes and the fact that we stored it in stainless steel tanks kept the acid from neutralizing itself in normal steel tanks, allowing the team to get to the root cause.
PS: one must still ensure that elastomers are compatible and pressure/temp of fuel is adequate to prevent vapor formation, but corrosion should not be a concern.
Bill Lane
Building 7 tipper. QB,Canopy : on hold
G3X/GNS 650 Panel, Built by SteinAir
IO-360 M1B, Hartzell CS Composite
Wiring 98% sans FWF. FWF: Fitting SJ Cowl
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 07-12-2014, 06:12 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
My IO-360 Bought new about 10 years ago was from Superior and they recommended 92 oct eth-free mogas. Nuff said and I never looked back. It now has 650 hours on it in Dale Walter's capable hands with no issues.
At the time I tested it with 100LL in one tank and mogas in the other. With a GRT EFIS at 8000' and 75% power showed zero diff in MAP CHT/EGT. Running a bit LOP. Excellent performance all the way around.
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
