Thanks again for the advices. I'll try it with the card- stock trick, hoping the piece of the .016 sheet from the elevator will be enough. Cutting normally works fine. I'm using an oscillating saw with a very fine blade.
Nevertheless having read about Katie's backrivet-plate accident, it nearly happened once to me, also with the rudder skin. Since that I always use a magnet to check the position of the backrivet plate through the skin. Maybe, riveting takes a little bit longer but you can always be sure the plate is underneath. Simply fixed a small magnet to a 3" wooden stick, when it stands upright, the plate is underneath, if not, the stick falls.
