Old 07-05-2014, 08:47 AM
jsenft jsenft is offline
Default N Number sticker
Does anyone have a good source for a small N number sticker for the Instrument panel.
Old 07-05-2014, 09:28 AM
Michael Henning Michael Henning is offline
A P-Touch label maker.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 07-05-2014, 10:48 AM
Paris12Man's Avatar
Paris12Man Paris12Man is offline
Default Plastic tag
I went to the local trophy shop and had plastic tags (like name badges) made. They have a sticky back to adhere to the panel.
Steve Garrett - 903-272-5639, scg3037@icloud.com
N905RV - 520 hrs to date
Home field XS30
Old 07-05-2014, 10:49 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I did that too, only I had them made from metal. Should last forever.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 07-05-2014, 12:51 PM
I printed all my instrument panel labels as black type on clear tape and sprayed clear matte lacquer over the whole panel after applying them. It gives a longlasting durable result that looks professional.
Old 07-05-2014, 01:34 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Trophy shop. They can do things now that you wouldn't believe, and it is inexpensive. Computer - based text and graphics - no problem. It's not your dad's engraving anymore...
Bill H, RV12, N412BR "Sweetie", Skyview-equipped, KASL Marshall TX
Old 07-05-2014, 04:23 PM
Spoon Spoon is offline
I used doityourselflettering.com for the N number. The other text you can see in the photo was silk screened.
Kevin Spooner
RV-6 .... N71KS
RV-8 empennage
Pitts S-2A ... N161RH
Old 07-05-2014, 07:52 PM
Driftdown Driftdown is offline
Just had a new panel installed and in the process of doing my own panel labeling with a Brother P-Touch. I am using white lettering on clear tape. Panel color is dark gray.
Should be finished very soon and will post photos and comments.
Old 07-06-2014, 07:28 PM
knievel knievel is offline
I'll send you a vinyl paint mask of the number if you'll send me back a picture of the finished product. It will look silkscreened.
Old 07-06-2014, 07:39 PM
DonFromTX's Avatar
Local trophy shop did these in solid brass for 4 or 5 dollars total. I love them, they have sticky stuff on the back already too.
[IMG][/IMG]
