Hi All,
VH-OBY has now achieved first flight.
I decided to complete all of the test flights myself after completing some transition training with Andrew M and Dan P. All I can say it transition training is a MUST.
The first day of "pre-flight testing" resulted in some very cooked brakes. I completed some high speed (read almost take-off speeds) and then full braking and completed about 4 of these in quick succession. Needless to say, don't do this as it will cause some major problems.
I needed to refurbish the callipers, replace the O-rings, and due to the massive heat build up replace one of the tires. It was bad, however, I was luckier than others on the forums. So be aware the brakes work well for their purpose, but not when you overdo it.
Once the brakes were sorted out, late Wednesday afternoon 02/07/14, she took to the sky with a beautiful grace. All of the first flight testing went very well. I did have one issue that raised it's head and from all the discussions I have had with others, not so uncommon.
I had the trim switch inverted. Pretty easy to sort out with the VPX but a bit embarrassing. A few leaks showed themselves up in the brake system and the fuel pressure sender. All easily fixed.
Videos can be seen at the following drop box:
Take-off: 8MB
https://www.dropbox.com/sc/fq3vjwoff...BRqBKDlV4QFC_a
Landing: 18MB
https://www.dropbox.com/s/529lnwr00u7vh0t/Landing.mp4
In cockpit: 199MB
https://www.dropbox.com/sc/56y27tt3c...7RAM1ev913koxa
They are a bit large, however, I like them :-)
This is fun......
